Google the procedure for turning on cruise control with vagcom, if you can turn it on your ecu will accept it. Mine accepts it and is an AYP.
I will be doing this in the next few months, I have done lots of research seems pretty simple. Fit stalk, wire 4 wires from it to the ecu plug and turn it on with vagcom. Check your clutch and brake switches work on the appropriate block (66 iirc?) and away you go... Cruise control retro fit.
Sent from my iPad Mini using Tapatalk HD
