Cruise Control
ebo007
185
Dundee, Scotland
I have the instructions, (cheers Greag) but does anyone have the part number for the Stock and wiring from SEAT? Just to save me the time explaining to the stealers.
Richy88
no idea on the wiring loom you can just cut the plug off and extend the wires tho its easy
the stalk part number is in another thread somewhere aswell as the code for vag-com
greg
Newbie
Aug 31, 2005
256
Drop me a PM with you email address and i can give you wiring/installation info mate. Dont have part numbers tho
coco_cupra
hi can you tell me the reference of the cruise control lever? 4 wires out of the handle? blue red black and white? where I have to put everyone?
this is my wires..
i wait response thanks
coco_cupra
if and activated with vag com but it does not work. I will reinstall everything. the white wire has to go to the ecu? or just put it in the fuse 3?
Red wire - 57 in ECU
blue cable - 75 in ECU
white cable - fuse number 3? or ecu?
black cable - 38 and 76 in ECU
something more is needed? or so is all. then activate well with vag com and already finished? You can take a photo to your cables? I hope your answer thanks
Richy88
the white one went to the back of my head light switch or can go to the brake light switch then activate and it should work
Richy88
white wire goes to pin 2 on the light switch.
Black is split to pin 38 and 76 on the ecu
Red is pin 57 on the ecu
Blue is pin 75 on the ecu
coco_cupra
hello friends. richy the white wire goes to cable box red lights do not? but where should I put the box of lights? the number 2?see the photo
I divide the black wire in 2 and 38 and 76 pins. and the red wire to 57 and blue 75. then just activate the vag com? i wait response
EYEbeefATDI
TDI C/C wiring
Hi guys first post for me, hope you don't mind.
I was just wondering if anyone could confirm if the wiring is the same for TDI ibiza's?
Cheers,
Tom
A2RRR
hi guys.. is it possible to install cruise control on a 2001 (51) Ibiza Mk3 1.4 cool.. if yes then can somebody let me know what the part number is and send me some wiring info please..
Cheers, Azz.
coco_cupra
[QUOTE = A2RRR; 2670829] Hola chicos .. ¿Es posible instalar el control de crucero en 2001 (51) Ibiza Mk3 1.4 Cool .. si sí, entonces puede alguien hacerme saber lo que el número de parte es y me manda algo de información de cableado por favor ..
Cheers, Azz. [/ QUOTE]
hi. if your car has electronic throttle if they can install cruise control
byee
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
hi guys.. is it possible to install cruise control on a 2001 (51) Ibiza Mk3 1.4 cool.. if yes then can somebody let me know what the part number is and send me some wiring info please..Cheers, Azz.
It was usually a case of the larger engines + Tdi only that could be retro-fitted for example the 1.4 Ibiza + 1.6 Leon never could but try the coding first to double check but never had one work on a 1.4 yet
a note to anyone considering the kit before buying/fitting it all in there is a simple way to test if it is possible and that is by activating the cruise control code and making sure it is activated on the ecu, at least you will know before buying/fitting the kit
From Ross-tech/Vag-Com
Activating Cruise Control on a new ECU (DBW):
Factory fresh ECU's often come with cruise control de-activated. If this is the case, there will not be a letter "G" in the Component field of VAG-COM when connected to the Engine.
[Select]
[01 - Engine]
[Login - 11]
Enter 11463 to activate cruise control
[Do It!]
After doing this procedure, there should be a letter "G" in the Component field.
byee
wrong - not all the car's have the software coding capability so check it first
here's a link to genuine Golf fitting instructions that may help
http://vwgolfr32.co.uk/ccs.pdf
