Coding a RNS 510 - to show on MFD
Jammy78
422
Hemel Hempstead
I need help, as I'm getting seriously frustrated! I've got a new VCDS cable so I can access the navigation code....... yet I still can't get RNS 510 to show up on the MFD!
I've searched & searched - tried everything, yet no joy!
Can someone tell me exactly what coding I need to do or even give me there long code so I can copy it?
Or do I need to re-set the MFD once you've made a change or should it come up straight away?
I've got a 2007 Cupra & RNS 510 version c fw 3800
Many thanks
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
you need to go into the CAN gateway control module using VAG COM and select the option for navigation installed
Jammy78
422
Hemel Hempstead
WOOHOO...... SOLVED!
I had unchecked the BAP button in the navigation settings......... but YOU NEED TO RE-BOOT the RNS 510 after a code change = the clock shifted straight away & then I knew....... BINGO!!!
I can go to bed happy!!!!
Jammy78
422
Hemel Hempstead
Very simple - you just need to cut out a bit of plastic under the unit (that's if you get the VW version)! I sourced mine from eBay, the seller was in lithuainia!!!
hammie2k
70
Sounds like the guy I got mine from a 18 months ago... You will need to Dremel the hell outta the plastic for it to fit because of the card reader. I also had to cut a bit at the back where the GPS comes out :)
hammie2k
70
I never cut the bit at the back for the gps cable, did I need to?
Might have been the type of connector for the GPS receiver i bought but I had to cut a bit away or it would get crushed when the head unit was in it's correct place
philt90
2010 black Cupra R
Feb 12, 2009
109
preston
cool will try this is it possible to get the skip track and phone functions working on the left hand side of the wheel
