Hi guys , on the weekend i noticed a significant loss in performance with my car , no surprises there given the history
but its accompanied with a clunk , basically if i do a spirited burst you hear a clonk coming as the revs die , its not a suspension or something loose clunk its to do with the engine.
When i parked up i lifted the bonnet to see where this was coming from , couldnt hear anything on idle so got my girlfreind to blip the throttle a couple of times (max 2.5k revs) basically if you stand at the front of the car the noise sounds like its coming from around the dv region ( standard on my car) the noise sounds like 2 faces coming into contact with each other , like a piston spring loaded then released and hitting another surface , like a non metalic clunk , similar to the noise the piston used to make on the 007 forge unit when i serviced it to check the vacum.
sorry but noises are hard to describe.
any one else noticed this noise?.
on the sound clip the clunk is when the revs die down , sorry for the idiot talking
http://i653.photobucket.com/player....tobucket.com/albums/uu256/robdf2/MOV00201.flv
