Climate control model question
gazjones
its ok sorry about me thinknigh youy had not got climate control dont know why i thought that hope you get it running nice and cold!
RuiD
Will do Chemical Al, will do. Gaz... it won't go under 18º... it just stops there. Can it be a sign?
gazjones
ah right do you get it saying hi if you turn it right up past 29
gazjones
yea am doing if its not going past 18 degrees to LO then something dosent seem right there!
RuiD
No LO... no HI either. That rules out the A/C... but that's ok.
It makes sense: it doens't go under 18º because normal air circulating system can't go under that. It would have to be the A/C system.
RuiD
OK, guys just the update as I've been to service. It HAS A/C. It has gaz but maybe not enough to cut it in.
I'll have it attached to a machine to analyze it... maybe it's gaz, maybe some leak... ot something wrong with the system.
Thanks a lot for your comments.
