Chris_a_73's Ibiza Reader's Ride!
Chris_a_73
1.2L Ibiza Mk4 '07
Oct 27, 2009
1,949
Guildford and Bristol (uni)
Now the question is, do I lower it? Could go 30m on lowering springs and perhaps end up having to replace shocks soon after, or just go for cheap coilies like JOMs.
What do you guys think?
marksy93
In an Ibiza..FR This Time
Aug 26, 2010
838
N.Yorkshire
just buy some coilovers then put a drop on them that is subtle and by the time they have bedded in properly they will be low enough :)
+1
the only reason i would reccomend coilovers is because when you come to sell the car you can sell it with the OEM shockers and springs and know that the shockers arent going to be ruined. Also while driving it normally if the shockers are running with a shorter spring they are constantly under more tension than needed, therefore causing leaks etc and further problems.
just get some coilovers, drop it around 45mm and let them bed in then see what you think. Atleast with coilovers (depending on what you get) you have the option to run from a set up of a 20mm drop to a 120mm drop
Chris_a_73
1.2L Ibiza Mk4 '07
Oct 27, 2009
1,949
Sad car is sad :'(
Got a screw in my tyre the night before I drive to Bristol and back.. I'm going to have to nip down to a tyre shop tomorrow morning to get it repaired!! Strangely enough, my dad got exactly the same screw in exactly the same tyre in exactly the same place in one of his Defender tyres.. Co-incidence or someone being a d1ck?
This picture proves how rubbish OEM standard alloys are for this model!!!!
Chris_a_73
1.2L Ibiza Mk4 '07
Oct 27, 2009
1,949
Those wanting properly white LED sidelights (not these blue pieces of rubbish) buy these! Only £1.88 for 2!! I've bought roughly 6-8 different types of 501 LED SMD sidelights, and these are without doubt the whitest LED I've found! They match 5k or 6k HIDs perfectly. Fitted them this afternoon and I'm a very happy chappy. I no longer feel a bit shady when driving behind police :lol:
http://www.ebay.co.uk/itm/300674214...X:IT&_trksid=p3984.m1497.l2649#ht_4189wt_1190
