Changing top mounts
dg-1984
254
Glasgow'ish
Hi, I am going to change the top mounts and bearing on the LCR after work tonight and just looking for a quick How To guide or any hints and tips that you may have to help me out to make the job any easier.
Thanks.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
undo top mount nut
undo base strut nut
remove suspension strut
spring compressors on spring
undo spring retaining nut
release bearing and top mount.
refit is reverse of removal.
on lcr youll have to remove arb link from strut.
drivers side will be harder as less room to remove strut.
youll need a 7mm allen key to remove strut top nut, or use a spark plug socket.
cold chisel to split the hub to remove the strut...
fairly strait forward but struts can be a pain to get out of the hub.
use anti seize on all nuts for half hour before trying it.
joely
66
Towcester
I did mine, the worst bit it gettin the strut out of the hub, can't you wait till the weekend to give you more time...?
Also, top tip on driver side (or both): drop the sub frame down, there is only two bolts holding it, don't completely remove the bolts though, doing this will give you more room to remove the strut once released from the hub.
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
why not leave the strut on the hub and remove the 3 ball joint nuts ( obv marking them for camber )
and pull the full strut and knuckle off complete. Obv removing all ABS sensors brake calipers and warning wires
dg-1984
254
Glasgow'ish
Would this not require the brake lines to also be disconnected if the calipers are coming off with the entire hub and strut?
That would mean extra work with bleeding brake line etc when reconnecting.
Now tackling at the weekend give me more time, also ordered ths dogbone mount so can fit at the same time.
dg-1984
254
Glasgow'ish
Just replaced the mounts and bearings over the weekend, started on the drivers side and was a bit of a pain in the arse, top tip would be to drop the subrame down a bit to give you that extra clearance. Had the car jacked up both sides so undid the 4 bolts and gave an extra drop to help removal.
Spring clamps were hitting the top of the strut which didn't help but a big bar leavering the wishbone down the way helped alot, bit of oil round the bottom of the strut also helped.
Passenger side only took 15 mins to get out after learning on the drivers side, not too bad a job but definately drop the subframe to give extra clearance.
Managed to snap the lower strut bolt aswell when putting it back together so need to get another one ordered asap and get it replaced.
Also found the the inside of the tyres were worn bad so will have to replace the wishbone mounts then get a 4 wheel laser alignment done.
robertbadlad
138
uk gloucestershire
this might be a silly question but why do you need to clamp the springs? do they need to come off? i was told by the fitter at work that there no need to remove spring. ??
