changing my 210 steering wheel for the 225 one
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
Just got a 225 steering wheel
I was planning the whip off the old one and put the new one on, however, i think i'll end up with an airbag in my face
Has anyone replaced the steering wheel before?
if so are there any tips you can give me? I've found the cruise control one
Should i be doing anything like leaving the ignition on etc ...
i've done a search and it looks like a few people say disconnect the battery or use vag com, but there is no definate answer on if the vag com route works
Can someone comment on this and also tell me where in vag com i disable the airbag?
Icecavern
6,214
Berkshire, UK
www.icecavern.com
I'd disconnect the battery for 30mins before doing it, then leave it like that until you're sure that all the plugs are back in. Then the ECU will never know it's happened so no need for a reset with VAG-COM.
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
aha thanks guys
is it easy to disconnect the battery, i looked at it before and saw about a billion wires coming out of the live!
can i just disconnect the live wires and leave negative on?
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
just disconnected the battery as to wait the 30 mins and pulled up the article
it says i need a M12 spline drive, never even heard of one so i take it my socket set wont suffice?
c11rgd
Freshie
Sep 27, 2006
166
dont know if youve already done this,
but just make sure the car is off, ie disconnect -ve
dont put key in.
out a thin strong phillips screwdriver in the little holes at teh back of your steering wheel and push the clips which hold teh airbag in placem on either side, you will see teh airbag unit spring out a bit
then remove the unit and disconnect he two wires,
use your splin and remove teh steering wheel,
notice the notch mark at the top
and replace with new wheel and do reverse of steps
but with airbag just push it back into place,
make sure all connectors are connected properly and tucked away nicely.
and thats it.
c11rgd
Freshie
Sep 27, 2006
166
not esy tocoe by, an get snaped up fast. the R32 one is fatter and easier to obtain but maybe more expensive.
