Car keeps falling Asleep??
Smart22186
Newbie
Feb 21, 2006
353
Peterborough, England
i cant describe it any better then title?? when ever the car becoms stationary and the reves drop to idol, they then keep droping and then the engin just stops, but without any juddering or noise? half the time i dont even know its happened?
Put a brand new tank of tesco 99 in the other day (first time car has ever had that cause i just could not get to shell)
I have a 1.8 20VT, with pannel filter.
normally i can feel the engin at idol cause of my upgraded dog-bone mount, but its just so still not vibration or any thing, i dont seem to fight against switching off? (as if u would when u switch it off at key)
could it be the air folw sensor? i am really stummped, but ive noticed its worse on really hot days???
RogerW
Viking
Feb 26, 2005
56
Norway
Check that your radiator fans work as they should. My car stopped when stationary because the fans didnt come on. (Thats how I found out that the low speed setting on the fans didnt work, which eventually lead to replacement of both fans, relay switch and fuse)
Smart22186
Newbie
Feb 21, 2006
353
As i left 4 work this morning, i thought 2 myself
......how many ppl are gonna reply "maybe its tired"??? hmm lol
how do i check the fans work as they should??? i mean how do i know they ment to be on
RogerW
Viking
Feb 26, 2005
56
Norway
They should always be on, when the aircon is on. (slow speed)
"The fans on an LCR (don't know about the other models, but think it's the same on Ibiza Cupra's) have 2 speeds - slow and fast. The slow speed is meant to run continuously when the a/c is on, to keep a slight draft over the radiators - in particular the a/c one. The higher speed is for when extra cooling is required. Those of you who's cars, like mine was, have the high speed fans cutting in every 20 seconds or so, it is likely that the relay switch has failed (or the fans have both lost their low speed setting).
Because the fans are now regularly starting and stopping on the high speed setting, this causes stress on the motors. This in turn can cause them to fail. I think I mentioned earlier in the thread that mine had sounded like an air raid siren for a while - one of the symptoms."
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
My audi did this? Do you revs somtimes drop really low when you rev standing still..
Rev up then let it go back to idel.. Does the revs dip then that car go OOOWW then it jumps back up
My audi did this.. Used to be a fu**cker at roundabotu when u go to pull away. You lean forward and nothink!!!
.::Edit::.
because it tierd :lol: There ya go :)
Smart22186
Newbie
Feb 21, 2006
353
.::Edit::.
Yup exactly that!!
whats a throttle body and how do i test it?
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Ok yep just done a search, gotta disconnect battery and wait 5 mins, then re-connect swicth on ignition and wiat till some noise stops????
that sound right?
Do you have vag diagnostic? Help scan for any faults and measure reading from some of the sensors
Smart22186
Newbie
Feb 21, 2006
353
Ok, right done the reset thing, took the car for a very short spin (lol 1mile) seemed ok, will have to post back I’m morning to be sure.
Na don’t have vag com, wanna get it just no idea what to get lol need to do some research,
Checked the fans, with climate on, only 1 fan spins up is that right???
GrayT
I'm Old
Jul 7, 2004
812
London
I think it's just the one fan at slow speed for when the air con is on as that's all that's required. But ensure the fans kick in at full speed when you've got the engine nice and hot.
