CAR ALARM - with REMOTE ENGINE START
StuLCR52
MK1 LCR project….
Sep 11, 2005
136
Hampshire (formally Lisburn NI)
Ahh yes , you got the leon last year. I didnt recognise the debadged boot!!
Believe it or not manchester/brum/swansea have worse car theft statistics than over here, probably as there is a larger population between them. there wouldnt be many thefts from the likes of portaferry etc!!
psssst its only photoshop lol
portaferry car crime never lol portadown id believe ya lol
stu
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
rashcupra u will get differing advice, but if u want it get it, my mates from ni have it on most of there cars, they can afford it lol, they dont have waterpump failures etc to contend with lol,
if u got the cash, be flash![B)] lol
and just be sensible were u use it.
stu
cheers for the advise, just would be nice to know if some1 could steal my car even if i had an exspensive clifford fitted :shrug:
im gonna splash the cash on the clifford tho :D even tho i dont have it :lol:
StuLCR52
MK1 LCR project….
Sep 11, 2005
136
no matter wat u do to ur car they will try, there tossers with a capital toss!
ive always had clifford, stopped them stealin my ibiza in n ireland,
oh go on by it ne way u can always pay for it later lol.
rashcupra
Oct 15, 2006
6,517
crawley
my car got keyed the other night maybe if i had a better alarm some knee caps would be smashed ;) luckily i work in body shop and it was sprayed same day :D
I had intellistart on my Clifford Ace 7500 system fitted to my corrado, its a brittiant system and the car stays locked when its running, if you open the car and even touch the pedals without putting the key in the engine stops. Also i had blackjaxx, there is no way you could nick it without knowing the code. I'd never fit one to my Leon, technology has changed since intelli start came out.
leon7284
Chelsea Chelsea
Jun 13, 2006
365
Horsham, West Sussex
Like Icecavern says says if its installed properly 1st the alarm will go off causing it to shut down, if that fails 2nd the steering look will kick in, if that fails 3rd touching the brake will cause it to shut down. So to 'knick' a car while the intellistart is running you would have to hot wire it which would really be the same way if they would have to 'knick' it with no intellistart and no keys.
So i think intellistarts are safe and also i think that having them not in 'noddy mode' is ok because if started in gear it'll just stall three times. Only in the event of leaving the handbreak off would it go wondering, but surly if the handbreak wasnt on it would have already left your drive!!!!
leon7284
Chelsea Chelsea
Jun 13, 2006
365
the intellistart has to be set to manual or auto transmittion, if you set it to auto on a manual box and try and start the gar with it in gear, it will blow your starter motor as the crank time will burn it out.
Dont know how mines set up then as it aint done that to mine!
I was just asked if i wanted to be able to start it everytime (which i did) or weather i wanted to have to activate the intellistart prior to shutting the car down.
This is called 'noddy mode' i believe
Icecavern
6,214
Berkshire, UK
www.icecavern.com
No it's called the correct way to instal it. Any installer that is happy to install intellistart to think it's an Auto rather than a manual shouldn't be installing them IMO.
leon7284
Chelsea Chelsea
Jun 13, 2006
365
an manual car it should be actviated prior to turning the car off, also that way if the alarm is trigger the intelli start function is cancelled and the car wont remote start.
But mine still triggers it so cut out and mines set to start anytime i push the button.
Only bit about the whole intellistart thing i dont like is having my LCR immobilisor for the feul pump continuiosly unarmed by sticking it to the ignition barrel. But the Clifford does immobilise the starter motor though!
