Cambelt Kit cost
Johnny Hotrod
58
North Yorks
Can anyone give me an idea of what this should cost & where i can get one from at a good price - just the kit not fitting. I have a 2003 Leon Cupra
cheers :)
Cadge
The kit cost me just under 100 notes from the dealer...for a cupra tdi....HTH
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
how do you know the kit your ordering has the metal impellar for the water pump
as this is vital when doing the cambelt/pump job
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
i've asked kez this as he has the ecs kit on his lcr
just seems like your paying for the name for me
i wont be bothering with ecs kit over OE unless i got some decent reasons to
andyj
There's no F in Quality..
the ECS kit is all OE parts, including a waterpump with a brass impellor, for £170.
the same parts from a main dealer will cost you £250.
I have just had the main dealer prices confirmed as above, and also the labour charge is approx £300...... for 4 hours work. But this is approx, as they have said it depends on how many problems they encounter when doing the work, seized bolts etc.
andyj
The ECS kit contains the following (for £170)
* OEM timing belt made by Continental
* OE tensioner Roller made by NTN-Japan
* OE tensioner assembly made by NTN-Japan
* OE Idler roller (comes on the tensioner assembly)
* Hepu water pump with metal impeller
* Conti-Tech accessory drive belt
* Behr thermostat
* ECS/OEM motor mount bolt kit
* Camshaft seal
* Crankshaft seal
The equivalent kit from the main dealer is:
06A121012X Water Pump With Sealing Washer
06B109119A Toothed Belt
06B109243D Tensioner
06B109244 Relay Roller
N10209603 Bolt
N10516701 Bolt
06A260849B Ribbed Belt (with aircon)
06A903315E Ribbed Belt Tensioner
06B109477 Tensioner Damper
and will cost you £250
this was probably for just the belt and tensioner...... I'm guessing by the price.....
Mr Az
Wants it wide & low
Nov 15, 2007
137
Bucks
www.myspace.com
My girlfriends brother works as a technician for skoda, so he's going to sort it all out for me. Don't know exact part details but he said it will be all sorted for £139, with £100 being labour
p1tse
294
go with oem items i would say
think prices are £300 give or take £50 for a good supply, and fit including water pump
andyj
as posted earlier, my local main dealer had quoted £520+ for supply and fit of just the cambelt and tensioners etc, without the waterpump !!!!
mind you, they're rip off merchants.... they wanted £200 to change a front wheel bearing on my LCR, when the other closest dealer only wanted £85 !!! :lol:
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
* Behr thermostat
* Camshaft seal
* Crankshaft seal
N10209603 Bolt
N10516701 Bolt
Thanks very much for that andy mate, answer i needed. Ill be going with the ECS kit come change time;)
andyj
you're welcome mate ;)
I had it all on a spreadsheet, as I've been costing it all up over the last couple of months in preparation for getting mine done!!! ;)
I just need to find somewhere to fit the ECS kit now.... all the local VAG Dealers will only fit their stuff.
There are a couple of local VW Specialists that I'm going to try ringing today.
