Can anyone give me an idea of what this should cost & where i can get one from at a good price - just the kit not fitting. I have a 2003 Leon Cupra
cheers![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
cheers
£39 from skoda! Its the same engine as the Fabia RS. Thats for the Belt and Tensioner. Getting mine sorted on saturday![]()
Awesome GTi do the ECS Tuning kit (inc all belts, tensioners, bolts, water pump etc) for about £175+vat
The kit cost me just under 100 notes from the dealer...for a cupra tdi....HTH
The ECS kit contains the following (for £170)
* OEM timing belt made by Continental
* OE tensioner Roller made by NTN-Japan
* OE tensioner assembly made by NTN-Japan
* OE Idler roller (comes on the tensioner assembly)
* Hepu water pump with metal impeller
* Conti-Tech accessory drive belt
* Behr thermostat
* ECS/OEM motor mount bolt kit
* Camshaft seal
* Crankshaft seal
The equivalent kit from the main dealer is:
06A121012X Water Pump With Sealing Washer
06B109119A Toothed Belt
06B109243D Tensioner
06B109244 Relay Roller
N10209603 Bolt
N10516701 Bolt
06A260849B Ribbed Belt (with aircon)
06A903315E Ribbed Belt Tensioner
06B109477 Tensioner Damper
and will cost you £250
this was probably for just the belt and tensioner...... I'm guessing by the price.....
