Buying an FR TDI - Things to look for?
seat_rich
Five atoms
Jul 29, 2009
179
As the title really, I'm currently looking at a ~ 70,000mi FR TDi on a 54 plate, around the £5k mark.
What should I be on the lookout for?
The only thing I know about is the cambelt change, but other than that I'm a complete novice at giving a used car the once over!
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
have a look in the FAQ section as there is a thread on the common problems/things to look for
seat_rich
Five atoms
Jul 29, 2009
179
I've read that, so I'm aware of the things that might go wrong, I'm more thinking about things to look for / test on the actual test drive itself.
Obviously I'll do the whole 'making sure every switch/control/dial/feature' works, but as an example, if I was buying an ST, I'd make sure to listen for a clicking driveshaft whilst taking up load.
Is there a similar 'test drive' list for the Ibiza?
st10587
Oct 4, 2007
3,669
Hindhead
make sure the clutch is not slipping when underload, knocking suspension mounts, make sure its pulling in every gear and check for excessive smoke, check for full service history.
seat_rich
Five atoms
Jul 29, 2009
179
That's great, much appreciated!
PS Can you remove the link to your car from your sig? It's already tempting me to start modding and I haven't even bought it yet :D
EDIT: How would I recognise knocking suspension mounts, or is it just a really obvious knocking?
st10587
Oct 4, 2007
3,669
Hindhead
the way foward is in my thread :cartman:
its quite obvious to know if they are knocking on uneven/bumpy roads. its a good point to lever some cash off and if your mechanically minded will cost about £20 for a set of front top mounts :) just will involve stripping down the front suspension to fit them
Hudson
389
Bilston.
Mate in all afirness and the experience i've had with my 06 plate fr... I'd suggest lookign else where.
st10587
Oct 4, 2007
3,669
Hindhead
sound like you had a bad one! i had a shocking example of a mk4 with my 1.2 but the FR has been awesome!
seat_rich
Five atoms
Jul 29, 2009
179
Well, fingers crossed. I'm taking a 54 plate for a test drive at the weekend.
With any model I suppose you get the odd nightmare (god knows my ST has given me enough stick when there are hundreds of others on the forums that have been trouble free).
Just luck of the draw I guess.
st10587
Oct 4, 2007
3,669
Hindhead
i work for BMW and lets face it we get the odd bad £70,000 7 series of course your going to get the odd bad £13,000 ibiza.
seat_rich
Five atoms
Jul 29, 2009
179
Never mind a £70K BMW, just look at Clarkson's non-functioning Ford GT (yeah, I know, it's a Ford, but it's hardly a Ka).
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
which suspension mounts knock? ours has started doing it when turning left. sounds like spring is moving in top mount type of noise.
st10587
Oct 4, 2007
3,669
Hindhead
thats where ours is coming from but i can't find where.
ive had antiroll bar bushes, anti roll bar links, lower arm bushes done under warranty and still havbe the knock. the i put coilovers on knock still there. so the only thing i can see left is the top mounts
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
i'll check the drop links and anti roll bars bushes. it does it randomly
teepee4bh
Returning old timer
Apr 19, 2009
203
Durham
drop links ok
anti roll bar bushes ok
noticed a mark on steering arm and corresponding one on roll bar - maybe
Only leaves top mounts now amd only happens at slow speeds and usually when turnng
or parking
