Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
I am still really pleased with the colour. These were taken just before the accident. I wanted the utilitarian stealth estate look. It actually looks meaner when filthy, but my brain won't let me leave it like that for long!
I have it in Sport mode more often than not, and knock it in D instead of S to drop the revs and keep the exhaust noise.
What do you mean knock it into D instead of S? My first DSG car and i've not had a chance to read the manual yet so this could be a silly question![]()
When you put the car in sport or cupra mode it puts the DSG in to sport mode as well so holds the gears longer and keeps the revs up. You can also put the DSG in to sport mode by pulling the shifter down while its in drive (just push it down and let go) you will see the gear indicator in the top right of the drivers info screen change to S and the gear number i.e S2
If you then pull it again it goes back to normal drive mode. You can do the same if you want to briefly use the paddles on the steering wheel and then put it back to normal auto. Change gear with the paddles and when you are done tap the shifter down.
I saw you in Dordon on Saturday late afternoon, your car looked filthy![]()
Ha ha! Yes you did and yes it was! Were you hiding in a bush or something? We went to pick up our new puppy from Warton. An early Christmas present for our girls. I'm puppy sitting this very moment, instead of cleaning the Leon!
Or put it in economy engine mode and get the E setting on the gearbox and it coasts every time you let off, very weird feeling
How do you set that one Jon? havent seen / tried it yet![]()
Dave
I'll give that one a go later when i pick up the missus from work.
Do you guys find that the stop start kicks in a bit too soon as you come to stop? The first time it kicks in seems to wait until you stop but after that the car seems to switch off just before you come to a complete stop sometimes.
I switch it off most of the time but there are about 6 sets of lights to get across town and when its busy you can be waiting a little while which is when i leave it on.
