Broken high-level brake light lens - anyone else?
andy_l
67
At least SEAT CS coughed up for the brake light in the end. Thanks for the update and pics.
greekstalion
Hi Guys
I have the same issue, my light has gone. SEAT refuse to replace too. Just logged a case with them and they asked me to take the car back to Seat dealer.
greekstalion
Mine is 28K, 11 months old, but the light was broken along time ago, but was busy with other issues,
a month after I got the car the piston broke, they recon the engine,
last month I changed one tyre and find out that the shock was leaking, they replace just one without wheel alignment,
the pin from the key (that holds the metal part that goes in the ignition) fell off. SEAT don't cover keys, AT ALL, under warranty, even if they fell apart.
Technology pack is really slow, sometimes it can take 3-5 minutes before you can use something, they can not find nothing wrong.
Some times when you get into the car it squeaking (suspension) like is 30 years old banger on the rear end. They found nothing. It was doing that since new.
Bad window design, if you open the window slightly when is raining the water fall inside the car, on the window switches.
Very bad service from the company. But I am lucky... is a company car so I don't own the car. The lease company don't care either.
I have logged a case with SEAT about the light and they told me to take it back to dealer.
After all these, I enjoy to drive the car, I just been really unlucky with it. Only if SEAT had a proper customer service but these days no company have any customer service. Every one of them are more interested on profits and they slip on quality and customer service.
dephead2004
918
12
You might get it as it's less than 12 months old . I expect they will quote external forces at you. But they should by now be getting a pattern of failure.
As for the rest of your motor, it sounds really bad. A Friday car, or in SEATs case a siesta car
Mr Pig
2,870
1,057
Thread resurrection. Happy days, the stop-light on my ST has cracked too!
20K miles, two-and-a-half years old, but who knows how long it's been broken. Phone call to the dealer on Monday and I'll ask if Seat UK has changed their position on this fault at all. It's clearly a flaw in the design of the part.
To be honest, I don't care if I have to buy the thing. What I want to know is have they fixed the part so that the replacement will not snap too.
So, how do you get the light out? I have trim tools.
Anyone got a part number for it? Are the ones on the ST and hatch the same?
Cheers,
Mr Pig.
dephead2004
918
12
The way NOT to do it is how the stealer tried ie Remove from the inside.
The manual says to use a special tool from the outside and slide it between the bodywork and lens and it pops out as the tangs are released. 10 mins allowed in the manual.
Mr Pig
2,870
1,057
Special tool? Might try a bit of cardboard. Once I have a new light that is.
trebor
233
33
Worcester
Mine cracked when the car was only 5 months old, same time as the rear light clusters were cracking. Dealer knew about light cluster issue and that was warranty but they were not sure on high level brake light with the CS response suggesting it had been hit by something. I argued that if it had been hit then there would bodywork damage in the area.
Was all done at no cost to myself. I believe Seat CS allow the dealers a small allowance per vehicle to cover things like this that are not warrantied, as a good will thing.
They must have done that many of these now though that they realise there is a real issue.
The rear light clusters were like this to begin with, but as more and more cracked they realised there must be an issue, looked into it and found that they were being over-torqued at installation.
dephead2004
918
12
Once you have one you'll see that there are no bolts or screws. Only the tangs hold it in place.
By the time the dealer had removed mine from inside it was unrecognizable
Mr Pig
2,870
1,057
Once you have one you'll see that there are no bolts or screws. Only the trans hold it in place.
Thanks. So just ping the clips on the top and it falls out?
I'll ask the dealer for a part number so that I can look for it elsewhere. might prove cheaper.
Interesting that the rear lights cracked because they were too tight. Good to know.
dephead2004
918
12
That's the idea. Part number is on my photo
Lykaios
27
Bedford
Stealers are doing mine tomorrow under warranty, As well as replacing the boot opening (where the badge is) as the spring to make it sit flush has failed and wont return to normal.
Mr Pig
2,870
1,057
I called the dealer this morning. The woman I spoke to said it was up to them whether or not it was covered by warranty, which I'm pretty sure is wrong, and they would have to examine it before they could do anything. I'm thinking 'It's snapped, what's to examine' but I've been here before so know it would be a waste of time trying the reason with her. I did ask her to call Seat UK to see what they said but she wouldn't.
I could waste half a day driving over there but I'm just going to mail Seat UK.
Lykaios
27
Bedford
When I went to stealers, they said it was known fault and are replacing them under warranty, not sure on recall tho.
az101
87
14
Burnham-on-sea
Just noticed this on my car also. Still in warranty. Just about. So they did cover it under warranty for you Lykaios? I've got a small list of things for the dealer to sort now so I guess I'll add this to it.
