I am guessing this is the LED failing
This is the self test as you turn on the ignition.
Does the same if you engage the handbrake.
Its intermittent. 7/10 times it lights up fully and as normal. Other times it flickers as shown in my video below.
Tried unplugging the handbrake switch and the brake fluid level indicator and it still does it.
VCDS does not indicate any faults.
Therefore ive ruled out the brake fuild level sensor and handbrake switch.
I guess its the LED in the instruments slowly failing, which looks from old threads a pain of full dismantle to fix.
UNLESS anyone else has any other thoughts on what could be causing it?
