No I'm saying it won't open as early as normal so the presure will build up be for it gets a to open so when it does open there more boost tgan normal = turbo 0-100% Insted of the uesall steady built up
ill help log your car again if you want. Im in porty and off all day. Have you checked hose from turbo to charge pipe if this has slipped of may be leaking air?
Well this made me chuckle Niall - I have been thinking long and hard about my issues again, and have realised that when I use my N75 switch (essentially unplugging it) the car is no longer noticeably slower, there is only a very minor change in how much power I have available.... This is making me wonder if I also have an N75, so I did a quick search for 'faulty N75' and see that my 'problem buddy' is thinking the same things haha!
As far as I can see, unplugging the N75 leaves it in its open state, I.E. feeding all the input to the wastegate (effectively bypassing any N75 functionality) and running minimal boost...
I don't know whether or not it is worth trying it with the N75 unplugged if you are thinking it is sticking? as this should leave it in the one state... having said that however, obviously you will run a lot less boost, so if it is something like a split hose creating a boost leak, the lower boost may not escape and you will think the problem is resolved as well....
This may not be of much help but just thought I'd mention the fact that you can try with the N75 disconnected just as another thing to try maybe?
Oh and you won't get an EML from it although it will log a fault code on the ECU showing N75 signal intermittent - scan the car with vagcom before trying this to see if there are any error codes shown with the valve supposedly operating normally, then try it unplugged and clear the code afterwards
Ben
Recirc valve is a Forge 007p fitted in reverse, it was brand new bought about 7 or 8 months ago.
When you say clean the throttle position sensor, do you mean the throttle body? Been meaning to do that for a while, had a code "19534 - Throttle Control: Airflow at idle too low" come up a couple of times in the past which suggests throttle body needs cleaned and aligned...
No sorry, I wasn't saying it is quicker with N75 disconnected, but the difference between connected/disconnected isnt as big as it used to be - when I first installed the switch it felt like switching between remapped/standard, whereas now there is very little in it.... on my last logs there was no evidence of a boost leak, so I wonder if its just not boosting as hard as it should be due to a faulty N75 sticking open and venting all the boost through the wastegate.... this would also be backed up by my turbo/DV not sounding as loud as they used to.....
Always something wrong with these damn things, I wonder if our cars were separated at birth lol
Sticking throttle body. When cold the flap is getting stuck on the gunk, then boost pressure overpowers the gunk and you get your boost "hit". Colder the weather, harder the gunk. Once it warms it softens freeing the flap and the car feels fine.
Clean your TB you mucky pupand re-align before doing anything else if i were you.
They're definitely chips off the same block i reckon! I think mine wasn't really cared for properly by one or more of the previous owners, had a few of the common things to sort out since I got it. What's this switch you're talking about? A switch to turn the N75 on and off?
LolSeems like a sound theory, will get that done as well, need to get a new TB gasket, hopefully next weekend. The car was doing it this evening on the way home from work again, like it was accelerating but forgetting it was meant to be on boost til about 3200rpm then bang, big-time boost all at once.
Will try disconnecting MAF this weekend anyway and try and get the TB cleaned and realigned next weekend.
on the bright side if it does turn out to be the N75 they have gone over to a new part number and the price has dropped down to about £38 quid as i found out today![]()
Apologies if this has already been asked but how old is the DV? If its over 10 months it could be sticking.
i would have thought that would starve it of fuel
sorry im backlol i could be wrong tho
