Audi S3 Strutbrace help
Deleted member 7729
these will fit all leons
and are well worth the money
iirc, brand new from audi they are <50
lower brace was about 25 all in including riv nuts and bolts
you asked about fitting kit for the s3 brace, iirc it was 6x or 8x m8's, nuts and washers. awesome gti fitted mine for 45+vat
tightens the front end up nicely
same as mine :) had mine fitted a few weeks back at JKM however does anyone else suffer from the engine cover vibrating aginst the brace :(
smoothuk
SmoothNAV
Aug 26, 2005
589
Essex
mine is sitting here against my desk begging to be fitted, i got a sparco one for my LCR. and a rear one on the way :) cant wait to get it fitted, think i may bet BBT to fit it for me, i just cant bring myself to drill the turrets...
daveyonthemove
Smile if you like SEAT's
May 14, 2006
1,519
Wrexham
Does the brace need to be 'modified' i.e bent atall to get it to clear/fit?
My brace started vibrating on the cover the other day. It always did a little from very low speed when your just getting the car moving, but once it was going i never heard it, however it was vibrating constantly after a service the other day, so i had a fiddle with it.
I pulled the engine cover off and found the rubber bit had stuck to the cover support. I tried to get it off, but with the brace in the way it made it tricky and it fell down the back of the engine. never to be seen again.
put the cover back on, and there is no vibration at all! Bonus.
so if your does vibrate, try removing the rubber from the support below the brace. it will allow it a few mm of clearance and avoid vibrations.
c11rgd
Freshie
Sep 27, 2006
166
Fitting
When all you guys say " im gettin it fitted" does that mean that the bolt holes are not present .
Bcos on previous cars i just remove the bolts which hold the suspension cap in place in the strut and tehn slide teh strut brace over teh top and re bolt it all.
from what im reading some of you guys are talking about drilling. etc
is this strut brace not a straight fit??
