Spent an hour or so on the dyno this afternoon.... I put the boost control back in the hands of the N75 and Bill loaded up the T1 file (the first file used from the original mapping).... couple of loaded sweeps indicated the boost request was still a little high hitting 28psi so a quick adjustment and hit 23/24psi so used that as a start...
First run netted 325bhp with no timing pull and fuelling at 12.5 AFR, added a little timing and then got a shade under 350 bhp @ 7300rpm again with no timing pull but then things were starting to go wrong... again!!!...
There was a rather large cloud of 'smoke' coming from under the car... only seemed to kick in at high rpm's which was odd... I currently have the PCV exiting down behind the back of the gear box until I get around to fabricating a catch tank so the first though was that the engine was breathing heavy and my heart sank... pulled the PCV connection off the top by the rocker cover outlet to see what was coming out while Bill loaded up the engine... hummm... nothing unusual, the normal amount of smoke you'd expect and no oil but not the huge clouds we saw on the dyno runs... it was only when Bill did a full run that the cloud appeared again... it was coolant leaking out from a water pipe somewhere by the turbo!!! DOH!!!
Bugger.... no point in doing much more until I find the leak... only happens under full load and high RPM so will be fine to drive normally for now but from the logs etc it appears that this first map file is a better start point than the run I have been running up until now...
On the road liquid is showing 291g/s and she certainly pulls well but feels flatter/laggier on initial spool so indicates the timing needs attention... no fuel dumping either so far but until I get the coolant leak sorted further tweaks will have to wait...
Onwards and upwards...
<tuffty/>
<tuffty/>
