Apexi AVC R Fitted.
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
My Install
SeatLeon20VT4
Seat Leon Topsport 20VT 4
May 28, 2004
73
Bergen Norway
Out driving
Out driving... Still got problems. The maximum boost set in the ECU is 1,45bar in my car, but now im not close to that boost. I understand that the Boost should keep more stable with the Apexi, so that you keep the boost over higer revs? The boost dropps faster than with the original N75.
Any pointers?
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
finally got mine installed! have had too much of a play yet as i dont REALLY understand it!
i can see from above you got annoyed with someone keep asking how to set it up but can you tell me the basic set up and then i will play
(bill said in post #85, "some setup to do also to convince apexi its got rpm correct.... cant remember off hand that setting. (think its 1,1,uparrow)
throttle is 0-5v setting")
whats that about?
Thanks in advance
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
ive been reading the manual for about an hour, starting to understand things alittle...keep popping out to the car and trying out what ive been reading!!
think im getting somewhere
but sorry bill im still not sure what you mean by that!? i may already of done it but im not sure what you mean! im guessing its in "setting" or "etc" section!?
thanks for your patience
HoocH
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
HoocH
if you look at Apexi in monitor view do your revs match your clocks?
h17och
Sep 1, 2005
3,504
Dunstabubble
not sure going to check asap bill
What setting should i use in the "car select" screen for "SPD"? 2,4 or 16?
is our throttle open with 3v-5v or closed with 3v-5v? (in other words should the arrow in the same section be pointing up or down?)
ive read the whole manual now i get the jist of using it but not sure on the set up yet
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
wire id from what you posted so im guessing my the same as you...? so is the arrow up or down?
what about the SPD setting? (speed pulse setting)
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
dun it how bill posted
righto..
thanks to matt for info....
Apexi wires ---- car
Red (ign power) - probe by fuse box for a suitable source.
Purple (rpm or inj) - Pin 102/T121 (bk/bl) - smaller ecu connector <<coil for rpm
Green - ground
Black - ground
Grey (throttle sig, 0-5v) - P35/T121 (gy/bl) - larger ecu connector
White (speed signal) - Pin 2/G22 (wh/bl) @ g'box sender
**Disclaimer-you follow this at your own risk. Applies to 2001 MY ibiza cupra's Mk3**
regards
bill
h17och
Sep 1, 2005
3,504
Dunstabubble
is there a possiblility that the purple wire is incorret?
I think im sorted with it all once ive sorted this?
cheers people
HoocH
