Apexi AVC R Fitted.
Yumann
1,638
Glasgow
What conditions cause the engine to go into limp mode is it overboost and underboost? Bill said if there is a 200mbar of deviation between request and actual IIRC.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
both. -ve deviation and +ve deviation can drop into limp
Jabba's controller was good in that it had a tap into MAP sensor so signals could be monitored and adjusted if req'd to prevent limp (I think) - as a controller it worked very well. I miss not having it working, and only just removed the thing out of my wiring this last weekend whilst wiring in the Apexi.
Yumann
1,638
Glasgow
You have the apexi working yet bill?
So say if you have the ecu mapped for 1.6bar and you set he apexi to run at 1.2bar will it go into limp?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
depending on how its mapped, possibly.
protection maps in place or not?
ask your mapper
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Any info you get would be good bill. Ive been reading a few jap web sites who use these and it basicly seems most are divided on whats best.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Does this help :shrug:
sroter
need help for all, i need this diagram ecu for install my new AFC NEO:
IG Power
Rpm
Thottle signal
Gound
Airflow pressure signal
My car is Ibiza turbo 2002 1.8T 20v motor code AYP.
Please HELPPP!!!!!!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
I have the wiring I have used for the Apexi but this does not include MAF.
inputs I am using are speed sensor off g'box, rpm off coil pack #1, throttle position off pedal 0-5v closed-open, boost from its own pressure sensor.
ground there are several points you will find under the dash. switched ign on is a question of probing with dvm, splice and fuse.. easiest probably down by fuse plate.
{edit-this is only going to be posted with the consent of matt as he supplied me the info)
