Apexi AVC R Fitted.
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
ive finally made sense of you post from before...you said "(think its 1,1,uparrow)" it all now makes sense :D
i think im already to go now! gona try set the boost up before i get it mapped!
soz for the ag-row of me keep asking...knew i would finally get there!! thanks
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
no worry bill, im still waiting for the zeitronix you reccomended! its coming from the states
i will soon post pics of my avcr install, its being put in the dash
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
i been having a play today... i noticed that the boost pulse's unless i put the duty on really high like 90%....does that sound right?
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
got a pic here...not very good but i keep forgetin to post a pic so here it is
excuse the half built dash lol
HoocH
Yumann
1,638
Glasgow
Does anyone have the wiring diagrams for a LCR?
Not that confident in cutting straight into wires by description
Also how did you guys splice into the cable? Cut back and solder or the clips?
Cheers, Yumann
Yumann
1,638
Glasgow
Cheers mate :cheers:
Bill have you set up the boost scramble function?
That looks like a very good feature for launches off the line.
C_u_p_r_a_m_a_n
HoocH
What's the speed pulse setting???
Cupra_matt I need ecu wiring diagram for Seat Ibiza Cupra '06 BBU.
MikeA
MAF Destroyer
Nov 14, 2005
92
Northants
Sorry I know this is an old ish thread.
I need to know if the Apexi unit itself is easily removable? e.g does it unplug easily or is it hardwired?
Around here, the unit would just get nicked, so I need to make sure it can be removed easily when not in use.
Cheers :)
Mike
h17och
Sep 1, 2005
3,504
Dunstabubble
hard wired! there is a plug but not made to be undone and done up all the time! doubt it would last long!
i put a hat on my dash to cover it!
HTC
Sep 2, 2004
421
Quick question about limiting the boost in 1st and 2nd gears.
I have mine on self learn for the duty which works great for me. I set the max boost and then control the spikes via start duty. Perfect boost every time :)
So if I want to limit boost in the lower gears, do I just turn the start duty right down???
Thanks.
HTC
Sep 2, 2004
421
Yes. All the correct values entered for the gears after driving the car and using the figures displayed via the unit. All inputs working as they should.
nick_p
hello guys.
i try to figure out with avcr and bosch me 7.5 on my ibiza cupra mk4.
i find the pin35 that goes to grey (tps)
i find the pin 102 that goes to injector1 for rpm
and i stack on speed sensor. whats going on. is there any puzzle behind of this?
pin 2 that you said before is the bigger pin that is ground.. can someone help me with that?
pm me or something.
