Anyone got Water Meths Injection on a Mk 2 Cupra?
Al
7,331
9
Well I was planning to do it for 2 weeks today, but i may have a longer look at it. Want to see what Dans set up is like first.
I have an appointment with a 12 second 1/4 mile and I am 18 hundredths of a second away :lol:
In seriousness, it would be a nice thing to have on a day to day basis too. The BSH kit is looking likely at the moment.
vRSy
Fabia vRS
Jan 8, 2009
1,470
London
dont be late for that appointment mate lol
to be honest if you are considering both options it might pay to wait a bit longer to research both your options. This direct to manifold injection does look like the perfect solution but will need professional fitment by someone who knows what they are doing.
what would you do about mapping. Maybe see if REVO Hq could do some custom mapping on yours
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
not really sure if i an going to go the route of mounting the nozzle in the intake manifold to be honest. i am mounting mine prior to the AIT sensor which seems to be the safest/best gain/easiest option.
RobDon
Pro Detailer
You're supposed to mount the nozzle a decent distance away from the throttle body to allow it to be properly absorbed into the intake charge.
http://www.alcohol-injection.com/articles/where-to-locate-your-alcohol-water-injection-nozzle-2/
"Most computer controlled engines have an intake air temperature (IAT) sensor. This sensor monitors the temperature of the air going into the motor. The reason for putting it before the IAT sensor is because it will see the cooler temps and the engine will advance timing, allowing for more power. Also placing the injection nozzle as far from the cylinders/air intake sensor as possible, it allows for the water/methanol mixture to be better absorbed into the intake air charge. This allows for great distribution to each cylinder. This post intercooler nozzle location should be the primary nozzle location to be considered for most users.
In theory, since the air charge will be mixed for a longer distance, and therefore time, allowing for the moisture to be absorbed by the air, creating the coolest possible air charge going into the cylinders. Water/methanol molecules from a nozzle located here have more time to be absorbed by the intake charge exiting the IC before making it into the combustion chamber.
My D04 nozzle is about 2 feet away from the TB.
Bruce-m
53
salisbury
A single jet pre IAT has to be done so the ECU see's the cooler temps, but it by no means the best or safest as it doesn't offer as good even distribution of WM, although single pre IAT is definately the easiest and offers still very good gains.
6 Intake manifold
This location can be the most complex area to install. Usually requiring that he intake be removed for access. Injecting here is going to yield the largest water/methanol droplets. And with the closer proximity to the combustion chambers is going to provide a larger amount of mixture into the cylinders. Doing this usually requires more fuel from the factory system be removed. This option is best for max cooling.
The water here is being injected in a manner much like port fuel injection and it is the bigger water molecules being injected here that have a more direct effect of in cylinder cooling and injection here has more of an effect of altering the flame front of the combustion charge in a way much like a higher octane fuel. To take full advantage of this nozzle location it is suggested that trimming away some of the factory dumped fuel be done. In other words, in order to take advantage of the better properties of water over fuel for cooling and injecting water at this location, you want to remove the dumped fuel and actually REPLACE this with water. This injection point with a pretty sophisticated WI control method allows for the most advantageous use of water injection. The drawback for nozzles located heres is kit/component complexity, install complexity, additional labor, possible machine shop costs, and possible additional parts costs.
Here is a bit of discription about the rest of the positions;
1 Pre-Turbo water
We don't recommend this location at all if you do not have the proper equipment such as the proper nozzle, nozzle size and high pressure pump. Locating the nozzle here is the most controversial location. The majority of alcohol/water injection users do not use this location. One reason for someone to inject at this location is the water/methanol mixture chemically alters the turbo compressor map. The water/methanol injection will dynamically shifts the compressor map of the turbo so that it has the compressor map exhibits the characteristics of a larger turbo. This sounds great but, the main issue with pre-turbo nozzle placement is what mixture can damage the compressor blade if the mixture is not properly atomized when passing through the turbo.
In order to inject pre-turbo with out compressor damage you need a high quality low volume nozzle and high enough pressure to get the water as finely misted as possible, and the smaller nozzle which allows for smaller/finer water droplets. We recommend you mount the nozzle as close to the compresser as possible.
2 Pre-Intercooler
Pre-intercooler seems like a sensible nozzle location but, the thing to think about is if the air entering the IC is pre-cooled, the ability of the intercooler is because the temp difference is lesser. It is also possible for the fine water/alcohol mist to collect in the bottom of your intercooler core. We don't recommend this location either. The other problem is that there's a possibility that the hot air from the turbo might unnecessarily vaporize the water and take up some of the volume built up by the turbo that was supposed to be for the charge. Pre-IC does work for some track cars such as road racing that operate at a more constant higher RPM. For the daily driver, weekend racer, the pre-intercooler location should not be considered.
3 Post Intercooler
4 Pre-Air Intake Temperature Sensor
In the cold side charge pipe is usually an easier or less intrusive nozzle location for most user's than the IC exit tank, but still the closer to IC the better. Locating the nozzle here has same as for reason given in above (location 3)
5 After Air Intake Sensor
After the Air Intake Sensor: You can usually mount it either before or after the ‘butterfly' and still be after the air intake temperature sensor. The main difference when mounting the injector before or after the butterfly is there is less vacuum before versus after the butterfly when idling or driving in vacuum. Translation, when in vacuum, there is more vacuum after the butterfly than before it. Here is why this is important: If your solenoid is placed very far from the injectors (more than a couple of feet), then the vacuum can actually suck just a little bit of the water/methanol. This small amount of moisture ingestion during vacuum is not a problem.
Cupra R
2,217
UK.
I run a BSH PCV bypass, but going to go to the catch can as i believe that the crap the pcv dumps should be dumped and not kept in the engine. I change the oil in the engine very regulalry though.
So what have you got on your intake manifold that used to be connected to the PCV? Can you not pick up boost from there?
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
so for the average WMI user would you say exit of the IC or Pre AIT sensor, i know there is only several inches between them but will it make any differance???
Al
7,331
9
A blank, same as anyone with a catch can. We will probably need to order a Forge spacer or similar to pick up boost.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Post IC, close to IC is the best position
if you have chosen Devils own kit, good luck with the controller reliability - I am not dealing with them any more... too many controller failures unfortunately
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
I take it you mean one of these.
Unfortunately not, when we fit the nozzles we just drill and tap, we aren't a fan of putting the nozzles in any sort of raised mounts as they can effect the spray pattern and create droplets/pooling.
eh?
only if rasied too high ... so spray cone hits side of pipe
Cupra R
2,217
UK.
You want to ask Forge if they would supply you with one of these then, it would be a simple fix for a pick up for your boost.
owen lcr
orvil
Oct 10, 2006
1,179
montrose, scotland
No bill after i spoke to you about all the horror stories we opted for your recommendation mate
Bruce-m
53
salisbury
We've had 4 fail in 4 years, 2 of those where because the boost take of for the controller was put right after the nozzle so water was getting down inside the MAP sensor and another was wired wrong.
Bad install is the most common cause of failure, yet Devilsown have always replaced straight away under warranty.
