Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
no probs
went to anthony's today ., its not oil its diesel leaking from pd pump think (luk stamped on it )
looks like its the cause of the start issues
also glow plug harness nees replacing too
any ideas if the gasket can be replaced ?? vw reckoned no
Feb 22, 2009
3,618
South Wales
Which pump? Pics?
was this the one we cleaned off?
if so have a look here
http://uk-mkivs.net/forums/p/321449/2220341.aspx
Andrewcupra TDI
Apr 30, 2008
3,282
good news
TPS do the gasket sets £5 odd
also ordered the glow plug harness
all in all £31.99
when im back from scotland i need to order
OIL
oil filter
Fuel filter
Steering rack end
all in all im hoping this is the end of the saga
and to start enjoying driving again (hopefully before summer as the bike will be out and car parked up !!! )
mark hurry up and start getting that bike roadworthy for the summer ) + some babysitters , take shel or the ride of her life LOL , scare her once , she wont want to go again
wish ide taken that option , beths been & pillion a few times now
Andrewcupra TDI
Apr 30, 2008
3,282
heres the numbers on my PD pump
LUK
BMF
038 145 209 A
BMI
if you can check yours mark
or someone clarify if thats a 150 pump and i pray its not a 130 unless they are the same anyways
as this was changed when i had all that trouble ages ago
cheers
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
not sure maz need to get my laptop back unless mark got his working
mark can u see if rob can put my isypropyl spray to oneside dont fancy somew kid wastimg it getting high not on my expense lol
27psi is what I am running so you really should be at around 23-24 PSI with a standard turbo.
Andrewcupra TDI
Apr 30, 2008
3,282
hmmmm
would the autometer gauges be in accurate do you think
or would it matter where you tapped into the IC hoses , regarding pressure
as from pics , we went for the rubber hose , by the header tank / fuel filter area
one of the reasons for me fitting one of these was to try and economize now and then :)
and try and remain off boost ,
only time ive managed that is by freewheeling or in too high a gear for the speed i,e 30 -40 in 5th
cheers
Andrewcupra TDI
Apr 30, 2008
3,282
also not sure if im panicin but in 6th when coming on and off the throttle while holding the gear stick
i can feel a slight knock / rocking type movement on the gear stick
only in 6th though
mark i also forgot that bike stand .. i will have it so tell him not to throw it out :)
