I ordered NGK BKR7EIX plugs mate, from Opie Oils. I ordered up a new pollen filter too as every time I use the aircon the inside of my car smells like wet dog.
Sorry, didn't answer a question from your previous post - yes I've left the N249 electrically connected. Originally I just ran a bit of 4mm ID vac hose from intake mani to the DV but when I undid the bypass last time I chopped the 4mm hose down so as just to go from the mani to the N249, then used 5mm hose from N249 to DV. Right now I've got a 90 degree hose joiner linking the 4mm and 5mm hoses together, N249 still wired in to the loom tho.
That hose you gave a link too at least looks the same as the stuff I have albeit in different colour. What internal diameter did you use? Like I said before, I used 4mm but maybe if it's not that the hose is too flimsy and collapsing under vacuum it could be that that's not wide enough...
Yeah boost gauge would be nice, just not a fan of pillar pods and don't fancy losing vents...
