312mm brake upgrade - a warning
JMWalton
85
looks good I'm after a 312mm &2-4 pot calipers setup for my mk5 1.4tsi fr it's sitting on fr 16's atm with 20mm spacers at the rear and putting 10mm on the fronts. Could you sort me out ?
Sent from my HTC One using Tapatalk 2
DEAN0
Old Git
Feb 1, 2006
5,366
351
Preston - UK
Not sure if you will get the 4 pots under 16" wheels.
The normal 312 single pot caliper is really close to rubbing on 16" wheels - I guess you might need to go 17" wheels first.
I would see if you can find someone with 4 pots and see if you can get your wheels over them.
JMWalton
85
Well I guess I could get some new wheels..... If I have to ;) I'll just tell the other half it's to do with the brakes . Looking at new wheels since I saw the car they look too small but can't decide what would look good
JMWalton
85
From the pics above I might actually have a 312mm set up on there. I'm not home atm so I can't measure them I'll check when I'm back from sea on Thursday. So how much do you think you could get me a 312mm set up single pot & 2-4pot if you could pm me some prices :)
DEAN0
Old Git
Feb 1, 2006
5,366
351
Preston - UK
Are they deffo 16" wheels ? - they are the same style as the 17" fitted to my FR
udqhu
Leon Tüpra R
Nov 29, 2007
14
Istanbul / Turkey
ATTENTION!!
You don't need Mk1 S3 or TT calipers to fit 312 mm disc anymore.
2013 Polo GTI's and Audi A1's have 312 mm disc.
You can buy a 2013 GTI caliper carrier and use your 2011 ibiza cupra/boc caliper on 312 mm disc.
DEAN0
Old Git
Feb 1, 2006
5,366
351
Preston - UK
ATTENTION!!
Have they not just fitted the S3/TT 312mm brake kit rather than create new parts.
Wonder if anyone has a part number comparison to check what parts they have done the conversion with.
jellybabybandit
170
So what the script with these setups ? What size is standard on my 2.0 tdi FR ? And is it a full setup I need ?
DEAN0
Old Git
Feb 1, 2006
5,366
351
Preston - UK
Your FR has the 288mm setup on it.
I bought a full matched set of 312mm calipers/carriers/springs/discs along with the brembo HP2000 pads.
I wasn't willing to risk the missmatch of components when it comes to the brakes.
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
Some of you guys may know, I've got 2 sets of 312's for sale at the moment, one red one blue.
Seba_N
I have made the 312mm brake upgrade on my Polo BlueGT.
Parts you'll need:
- Caliper carriers from Audi A1 (8X0615125A) these are unpainted. You can get also red (Polo GTI) or blue (Polo R WRC) carriers
- use the stock "Golf V" brake caliper
- brake pads from Golf V or Audi A3 8P will fit, I bought EBC RedStuff DP31517C
- 312 mm brake discs from Golf IV 25th Anniversary or Audi TT 8N (e.g. EBC BSD930)
- perhaps the OEM 10mm longer brake hoses, I changed to longer HEL braided hoses
Pictures are in here: www . vagarena . fi/index.php?topic=15217.msg458760#msg458760
It's in Finnish but pictures say more than thousand words :D
Reactions: Big-Pete
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
Got a rebuilt freshly Powdercoated red set of these with brand new pagid pads if anyone's interested
g_berserk
Smartass in training
Oct 15, 2014
164
24
Monterrey, Mexico
Anyone got the part number for the required hubs for those of us who are stuck with the 256mm FSIII brakes?
I'm so used to upgraded 312mm brakes from my previous car (lines, fluid, HP+pads, solid bushings) that I feel like I'm going to end against a wall on my new FR (1.2TSI)
dlok
95
ATTENTION!!
Hi, what setup does the ibiza cupra/boc have? Is the same as the 288mm on my FR 2.0 CR? If so am I right in saying from above the only items I need are carriers and discs from a 2013 gti?
Sent from my Nexus 4 using Tapatalk
jaydexstar
CAR TRADER
Dec 8, 2014
84
i have sat in my garage some golf gti mkv calipers, carriers, discs and lines, are these possible to get onta a 6j ibiza 1.6tdi ??
DEAN0
Old Git
Feb 1, 2006
5,366
351
Preston - UK
If your TDi ones have FSIII cast in to the outside of the caliper then they will not fit.
If they LOOK the same as the ones on your 1.6TDi ( spring on the outside ) then they will fit.
