Messaged the seller of the brackets to ask for confirmation of the centre to centre distance of the bolt holes for securing to the hub (should be 10cm) and they said it’s 9.4cm. I imagine they’ve just measured the distance between the holes not the centre to centre distance, they’ve also not specified centre to centre in their reply, just ‘the distance between the holes’ so I’ve just sent another message trying to get clarification.
And yes I was never considering the AP setup anyway but good to know it wouldn’t work anyway
. There’s plenty of options on eBay for 312 setups e.g. from mk1 TT’s but it’s more to do, not sure if it’s worth it as you said for 2mm extra but wouldn’t I then be able to get bigger pads in as well? And regarding the pedal travel distance I’ve read on other threads that it might travel a bit further but then bite harder?
However there seems to be more options out the for 312 discs as opposed to 310, for which I saw some OEM ones for £60 on eBay which seemed a good price or ATE, or a load of brands I’ve never heard of. As for the 312 there’s plenty of options from all the trusted brands, what discs did you get for your 310 setup?
