£2k for Vz3 discs and pads replace by CUPRA ??
tetrad
33
20
Hi
Just back from CUPRA after constant brake pad warning light. They have said my Vz3 (26000 miles, Dec 2021) needs new front discs due to pitting and new pads. Brembo brakes. £2100 to supply and fit. Anyone else had this done? Seems like crazy prices!
ChrisGerr
34
34
Hi
Have a read of my post
Chris
andy2max
34
18
I though my quote from the dealer of £775 for front discs and pads on my MK3 CUPRA 300 was expensive but 2k is just ridiculous.
AntoniosL
49
24
Although they are being called and marketed as Brembo brakes, the actual discs are made by SHW (only the calipers are Brembo) and they retail for £350 per item i.e. --> £750
The original brake pads are pricey but you can get decent pads for --> £70 - £85 (ATE, Zimmermann, Brembo)
https://www.autodoc.co.uk/car-parts...ive?criteria[649][]=Brembo&criteria[100][]=VA
As an alternative to the SHW disc you may consider the Zimmermann discs --> £560; I've heard they may be better compared to the SHW discs.
I opted for the following combination:
- DBA 52842 SLVS - 5000 series --> £970
- Hawk HPS 5.0 Performance brake pads HB806x.624 --> $140
An alternative to Hawk pads would be DBA's DB2228XP --> £200
If you insist for original brake pads (not my favourite) then you need to buy PAGID and the cheapest price I have come across is from Killer Brakes --> EUR 176 but inclusive of the wear sensor!!
Yes £ 2 K is a ridiculous price. Considering the above, the parts minimum price would be £ 630 + fitting or £1,170 + fitting.
In my case, fitting cost was EUR 50 for discs and pads together.
tetrad
33
20
Many thanks, I have tasked CUPRA Crewe to itemise the bill. I can only think they are charging for 2 packs of 2 discs rather than the one pack (2 discs) needed
