ok, only thing I don't understand is if you open the bleed nipples on the callipers and have to press the brake won't fluid go all over the place? Or you collect it and keep the reservoir topped up?
vag com bleeds the abs system which needs to be done if the system goes dry, do you just use clear pipes from the bleed nipples to the bottles or do they have to have non return valves on them to stop air getting back in the system?
your talking about a full pressure bleed im talking about bleeding the abs pump which uses vag com
