stoneyfordNI said:not much more u can do than that hope u get an answer , let us know the answer watever the outcome
Will do - time for some ZZZZZZZZZZZZZZZds cheers m8
sssstew said:or invest in vagcom to see whats happening....
Vag-com is a VERY useful tool to have, all sorts of sensor outputs you can monitor, log, graph, etc etc. You can run self tests, change settings (ever wanted to decrease the amount of assistance from the power steering, or enable your alarm chirp, or enable/disable to autolocking...). And of course read off and clear fault codes so you can start doing your own diagnosis when things go wrong. Being able to tell your dealer what the fault is when you take it in, is very useful !maxcars1 said:But isnt this why I leave it to more experience tuners and pay the fees for the developments - the people who know what there doing.
muddyboots said:Vag-com is a VERY useful tool to have, all sorts of sensor outputs you can monitor, log, graph, etc etc. You can run self tests, change settings (ever wanted to decrease the amount of assistance from the power steering, or enable your alarm chirp, or enable/disable to autolocking...). And of course read off and clear fault codes so you can start doing your own diagnosis when things go wrong. Being able to tell your dealer what the fault is when you take it in, is very useful !
Did you do this, and notice any improvement?muddyboots said:Have you tried cycling the actuator as suggested ?
This sounds like a very useful maintenance routine, think I might do it over the Christmas break.
No I haven't - to be honest I'd forgotten about it !dmjw01 said:Did you do this, and notice any improvement?
goble said:had this before on with alhambras wastegate seems to be working but when gets hot sticks causing it to overboost had to put car on rollers for 1/2 hor @ 70mph to get it to go wrong.changed tourbo all o.k
will be the fault guaranteed
stoneyfordNI said:the car in question has a VNT turbo-------no wastegate
I don't mean to unset you, but as I previously said, this is almost exactly the fault I had, And it took 11 months to sort. And yes in the end a new turbo. Seat seemed very reluctant to admit this may be a group fault; but finally did on mine. If you are out of warranty, and need the turbo replaced, it might be worth pestering seat central.
You have a PM
