N75 or Turbo Vanes
maxcars1
735
stoneyfordNI said:
not much more u can do than that hope u get an answer , let us know the answer watever the outcome
Will do - time for some ZZZZZZZZZZZZZZZds cheers m8
maxcars1
735
sssstew said:
or invest in vagcom to see whats happening....
But isnt this why I leave it to more experience tuners and pay the fees for the developments - the people who know what there doing.
muddyboots
Still hanging around
Oct 16, 2002
5,739
Vag-com is a VERY useful tool to have, all sorts of sensor outputs you can monitor, log, graph, etc etc. You can run self tests, change settings (ever wanted to decrease the amount of assistance from the power steering, or enable your alarm chirp, or enable/disable to autolocking...). And of course read off and clear fault codes so you can start doing your own diagnosis when things go wrong. Being able to tell your dealer what the fault is when you take it in, is very useful !
maxcars1
735
All very well, but this kind of fault can't be reproduced by the dealer. Therefore, I'm using a well known proven specialists that use the software. Unfortunately, it's proving a little difficult this one. Clearly I understand the benefits of vagcom, and it's something I will be considering in the future.
maxcars1
735
Well I've spent all day trying another MAF and N75/N18 valve and tested the car after each change - car still goes into limp mode [:@] . The car is still in standard factory ecu map. I've now just changed back to my original induction pipe and factory air filter for another run. I'm now running out of ideas. MAP, MAF and N75/N18 changed and still limp mode as a standard car :confused: .
Angusrob
129
Tayside
I don't mean to unset you, but as I previously said, this is almost exactly the fault I had, And it took 11 months to sort. And yes in the end a new turbo. :( Seat seemed very reluctant to admit this may be a group fault; but finally did on mine. If you are out of warranty, and need the turbo replaced, it might be worth pestering seat central.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
i think everything has been cancelled out , only thing left is turbo , have u tried the likes of 10K boost to see if itll free it up , only thing id be wary of, is lumps of coke getting into the chambers
muddyboots
Oct 16, 2002
5,739
If you do write to Seat Central, try and refer to Angus's case if they admitted his was a fault, it might give more weight to your case.
When I complained about my cracked windscreen, three other people off here sent me photos of theirs cracked in the same place, which I printed and included in my letter; they backed down and replaced it under warranty :)
dmjw01
Upstanding Member
Jul 28, 2005
442
Woking, UK
www.dmjwilliams.co.uk
muddyboots said:
Have you tried cycling the actuator as suggested ?
This sounds like a very useful maintenance routine, think I might do it over the Christmas break.
Did you do this, and notice any improvement?
I've done it a couple more times now, and I definitely have noticed an improvement. It's quite subtle, but the engine is less laggy and the power delivery is a lot smoother. It's most noticeable when you're just pottering about gently: pulling away from junctions and onto roundabouts etc. I guess the VNT mechanism was being a bit slow to deliver the subtle little bits of boost that you hardly notice. It's only now I've done this procedure that I realise the engine was being slightly hesitant before.
The question is, is my turbo doomed to get stickier or will this procedure free it up fairly permanently - perhaps just requiring a bit of exercise every few weeks? I guess time will tell. Obviously I try to welly the engine whenever possible (otherwise I'd have bought a 1.0 Nova) but a combination of traffic jams and icy roads often prevent this for several days at a time.
For anyone with VAG-COM, it definitely seems worth a try. I don't think it does any harm. ;)
Jun 28, 2001
1,533
had this before on with alhambras wastegate seems to be working but when gets hot sticks causing it to overboost had to put car on rollers for 1/2 hor @ 70mph to get it to go wrong.changed tourbo all o.k
will be the fault guaranteed:)
muddyboots
Oct 16, 2002
5,739
No I haven't - to be honest I'd forgotten about it !
Thanks for the reminder, I'd go out and do it - but it's around -6º now so it can wait :)
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
the car in question has a VNT turbo-------no wastegate
themutmonty
turbo problem
You have a PM
Hi guys,
I feel your pain. I have the exact same problem that you both have had. I took mine (ibiza 1.9 tdi) to my local stealer, the workshop manager took me and the car for a test drive, and whilst in the car admitted that these engines have a design fault, and that they had previously recalled cars to strip and clean the turbo's under warranty. but as is always the way mine is no longer under warranty and requires a turbo clean to correct the problem.
Angusrob you mentioned pestering seat central... did you do this? and did it work? if so how do you go about it?
Are your cars now cured?
thanks
Phill.
