I Recently swapped out my full suspension setup on my 2002 LC — went from JOMs/Bluelines to B4s with 35mm Amax springs. Everything’s felt solid, but about a week after fitting the front shocks (same day as the timing belt), I noticed a clunking noise at full lock during tight manoeuvres. I didn’t do the rears at the same time as I was waiting on extra hardware from LLLParts.
To be fair, I didn’t really notice the sound at first as I hadn’t driven it much after fitting the fronts. The video linked below is from when I first heard the noise a few weeks back.
I contacted DPM (where I got the springs) and they said it might just need a bit more tightening. Today I fitted the rears and got the fronts checked again — torqued properly as per AUTODOC, forums, etc. Still getting the same noise. All hardware used is brand new — top mounts, bolts, everything.
Any ideas what it could be?
Clip: https://youtube.com/shorts/vQ2-eDeLJGo?si=LWu8mG-QD3yUhYd3
Thanks in advance!
Thanks in advance!
