Unable to update MST2_EU_SE_ZR_P0516T
Nov 11, 2024
Hello all,
I was trying to install MST2_EU_SE_ZR_P0516T on My current MST2_EU_SE_ZR_P0468T but just clicking on the update.
This message pop up at beginning of the update : Unable to read the meta information file, dependencies of update not met.
NB: I have downloaded the files from mibsolution and metainfo2 file available on the main root folder sd card.
Any thoughts ?
Yours,
cairus
1,224
446
1) Idea to use the search function here in the forum. 2) Idea to use Google search... officially you can only update MIB2 with the same firmware range. So FW 04XX. to FW 04XX. You now have to carry out a manipulation if you want to get to FW05XX. Be careful, any manipulation can lead to the device being destroyed. Why do you want to update?
Nov 11, 2024
Hey Cairus,
I just to have latest version, if there is any improvements, current version running just fine without any errors, However I want to try latest one if it's safe and working, i will try the mentioned steps later.
Thanks,
SRGTD
2,677
1,524
Aside from @cairus ‘s note of caution on incompatibility issues, if it was my car and everything is working just fine with the current version then I’d not consider updating.
As the saying goes ‘if it ain’t broke don’t fix it’…………..🤔
Reactions: Tell and cairus
Tell
Basically mib2 standard has a train for each year of its 5 year life... almost. So each year they started a new train, however bug fixes were issued to each train. It's generally thought towards the end the fixes were on AA. Technically the updates were never meant to go from one train to another. If you do attempt to do it, it can hang in the reboot. Clash of memory banks. You have to take them apart and short pins. That's on a Google. Mib2 standard tool kit or something... on the Leon mk3 firmware thread can be used. Hobbyist thing to do a train update. But if your hobby isn't computers I wouldn't bother. A few people have now done that on the thread. More Skoda people. Seat drivers were late to the party. I kept saying there is nobody with experience here of that for a time, then it took off.
In the @East Yorkshire Retrofits can do this for you if you send the unit to them. Least that was a service they use to offer. The mib2 standard train firmware change and you get the unit back on 516.
Apr 21, 2025
Hello all,
Any thoughts ?
Yours,
Hello,
do you still keep that file MST2_EU_SE_ZR_P0516T? if yes, can you share it with me. I tried to look for it but the website mi solution is down.
thank you
Tell
Hello,
thank you
You have been saved. That is a train jump that can hang your unit. You are suppose to keep to the train you are on 4* in your case 5* is a train jump. The units software isn't design for jumping trains. You can use a tool kit for doing that @leonlad is the expert. The units are like early computers.
Anyhow if you had the VAG techinical notes it would say stick to the train. I could summoned @East Yorkshire Retrofits. They were offering a train jumping service at one time.
Updates and fixes are on the train. Not across trains. Why people wanted to change trains was when the tile view came in... 4* I recall so they didn't like the old way of doing things.
cairus
1,224
446
The tile view was HW03 with FW03... everything else was said. A firmware update, which would mean a generational change, should only be done if you don't care about the money or the device.
Apr 21, 2025
thank you for the information.
my current firmware version is MST2_EU_SE_ZR_P0512T.
So I guess I am on the train 5*?
it should be ok to update, no?
Tell
They tended to be Android Auto fixes why people did but if it's not broken why bother. It's the MIB3 ones that are more dangerous, so it appears. It might fix it. It was tuning that they were doing on these releases.
Some people thought that 516 was better than 515, others, the other way round.
