Ok, I asked Chat GPT and it gave the following. Would be interested to know if it workedWonderee if you still had the update file to 1940 or 1969 or is the USB C manu
Yeah i went settings system info I think it is where it shows you your software number then it has a button which is something like show updates and its blank![]()
I have the Files
I will try this when the misses is back with the car and see if I can do the above and let you know.Ok, I asked Chat GPT and it gave the following. Would be interested to know if it worked:
Yes, it is possible to force an OTA (over-the-air) update on a Cupra Formentor if the update is available. Here’s how to do it:
1. Connect to Wi-Fi: Make sure your vehicle is connected to a stable Wi-Fi network. OTA updates typically require a good internet connection.
2. Go to the Infotainment System:
Tap on the “Settings” icon.
Navigate to “System Information” or “Software Update” (the exact menu name may vary).
3. Check for Updates:
Look for an option like “Check for Updates” and select it.
If an update is available, the system should prompt you to download and install it.
4. Force Update (if no prompt appears):
Restart the infotainment system by holding the power button for about 10 seconds.
Reconnect to Wi-Fi and repeat the update check.
5. Accept and Install:
If an update is found, follow the on-screen instructions to download and install it.
Keep the engine running during the process to avoid interruptions.
If the manual check doesn’t show an update but you believe one should be available, it might be necessary to contact a Cupra dealership or use the Cupra Connect app to see if they can push the update remotely or provide guidance.
This video shows how to get to service menu and update from usbIs a manual update straight fwd i haven't seen a video other than one in Spanishdo I need to go up in stages or can I go direct from 1788 to 1940/1969 which ever is the latest?
Would you be willing to share the files?
Have you got those two files and would you be willing to share them with me so I can install it myself?From Firmware 17XX to 18XX To 1969
We're legally unable to distribute software update files, sorry. We do offer update services here at our workshopWonderee if you still had the update file to 1940 or 1969 or is the USB C manu
You'll have updates for other modules too, which cannot be DIY'd
If the software update from the dealer next week my next step will be to purchase OBD11 and do just that.
My experience is that the update at the dealer is not worth muchIf the software update from the dealer next week my next step will be to purchase OBD11 and do just that.
It's so annoying
Agree.It's so annoying
Yes - it allows the option of selecting Cruise, ACC or Limiter.Adding cruise is it just another option rather than removing ACC?
Not every HW/SW of the control unit 13 allows the CCS coding.Yes - it allows the option of selecting Cruise, ACC or Limiter.
