Golf R Quad tips
Feb 10, 2025
Seat Leon Cupra ST Mk 3
Has anybody bought quad tips from eBay/online. I'm Wanting to buy some that fit the stock diffuser without having to chop out bigger holes. Also what are the pros and cons to welding Vs clamped.
Thanks all
nd-photo.nl
3,960
177
The Netherlands
youtube.com
Do you want to use them on the stock backboxes? I changed the stock exhaust tips over for some ovals not too long ago. I clamped them using U-bolt clamps and they are holding up fine.
The height can be finetuned by lowering the exhaust mount.
Inner diameter: 51mm
External Width: 150mm
Total length: 170mm
See my build thread for the pictures: https://www.seatcupra.net/forums/threads/nd-photo-nl-s-seat-leon-st-cupra-280.477591/post-5072839
You can go a little bit wider than 150 and you will still clear the diffuser.
Total length: 170mm
Hi Mate,
Thanks for the response. Il check that out. Yer ideally just for aesthetics. So weld to the stock back box would be the way to go of it's possible. I think golf Rs are too big anyway at 220mm wide. So I need to go for somewhere in-between. Like you say 150 is max. Thanks for the info ,👍
Reactions: nd-photo.nl
Feb 10, 2025
What was the quality like from AliExpress and how long did they take to come? Really wanted Golf R but they are far too big. But then I don't know if 150 approx quads will be too small. Need to do some more research.
H Rafiq
1,161
491
Tip are just for aesthetics, aren’t they. No sound change. Quads do look nice on the STs.
nd-photo.nl
3,960
177
The Netherlands
youtube.com
For quad
Very happy with the quality, but it can be hit and miss. Took about 3-4 weeks to The Netherlands for me.
I bought these ones, 51mm in 150mm out
I used these clamps in 52mm
