heated mirrors?
missmouse
79
7
I assume these cars have heated mirrors? Mine dont seem to work! My Exeo & indeed all my previous VAG cars the heated mirrors came on when the rear demist was switched on.
Am I missing something?
serdar_18fr
508
Mirror heating switch is on the door. It probably shared the same switch with rear demister in previous generations.
Sent from my 23113RKC6G using Tapatalk
Reactions: missmouse and Mo_86
tracktoy
728
578
Select the heated mirrors if you want them to work.
Reactions: Mo_86
grabania
164
Warsaw, Poland
grabania.pl
I've got issue with heated mirrors when once my friend tried to code them to activate with rear window heater using CarScanner app. After that no matter what I've tried - dialing the knob, activating rear window heater, waiting for temperature to drop below 4 degrees - the mirrors were not heating. After restoring that coding everything starter to work as before 🤷‍♂️
Reactions: nd-photo.nl
BillyCool
726
297
Leicestershire, UK
I have my LH mirror set to dip when reversing. The switch has to be in the `L` position to do that and the heated mirrors will not activate. The switch has to be in the heated mirror position for the heated mirrors to work but the mirror will not dip. Slightly inconvenient but not the end of the world.
As above, make sure the switch is in the correct position.
serdar_18fr
508
That switch is one of the worst designs functionality-wise. It's overloaded, some of those functions should have separate buttons.
Reactions: BillyCool and Mo_86
Mo_86
257
92
UK
Not the greatest of pictures but this was my E60 535d, mirror had auto heating and auto fold.
There was a little slider to select left or right to adjust and if left in L or R, that side would dip. There's also a tiny button to close mirrors manually.
No auto dimming but the mirror had a factory blue tint.
Wonder if i could use normal blue tint on the Leon?
