Weird flushing sound after heater matrix replacement
Nov 12, 2024
You may have some trapped air. It's normal after a matrix change. The system is designed to self bleed but it can take a few weeks. Keep checking your coolant in the morning when it's cold. If it drops a bit keep topping up. Mine `gurgled` a bit until it finally burped its way clear. Took about 3 weeks and I topped it up about 4 times. I think some people also put the heating on max to encourage the car to circulate the coolant.
Yeh it definitely seems that way. What did the gurgling noise sound like (like area where the sound comes from etc) because I do here a weird noise which sounds to the left of my engine when in high revs at third gear. Also, do you know why the level would drop if the coolant weren’t to be leaking? Thanks for your help too.
Nov 12, 2024
Also any signs of coolant being higher than usual after driving(borderline overflowing)?
BillyCool
707
276
Leicestershire, UK
The sound I heard was almost as if it were behind the dash - possibly where the heater matrix hoses come in via the bulkhead. Can't be precise but I could only hear it when the car was turned off after a journey, certainly not when driving. If you have air trapped in the system, it slowly gets bled out and that air gets replaced by coolant. So your coolant level will drop a little but it's not a leak - just replacing air.
BillyCool
707
276
Leicestershire, UK
The coolant system pressurises when the engine is running, so the coolant level in the expansion tank will increase. It's shouldn't really overflow, unless you have trapped air that is now warm trapped air (which expands when warm) and the air is trying to escape. I can't say for sure.
You can always try squeezing the main radiator pipe between the rad and expansion tank. It's the old school way to try and purge air our of the system.
I can't properly diagnose it, so keep an eye on it. Also check oil is clean (no water contamination) as there could be other reasons over pressurising the coolant such as head gasket leak or charge cooler leak.
Hopefully - it's just some trapped air. When you replaced the matrix, how much coolant did you remove and then replace?
Nov 1, 2024
I have this noise. Its been there for weeks. Funny because i changed the heater matrix in my previous Audi A3 2014 and didnt have this problem with that.
Compo1
279
66
If you have VCDS
Bleed the low temperature circuit, basically it will activate the egr/matrix electric pump dispelling the air.
