High idle and fans running. Electrical?
Nov 11, 2024
14
Hi all I wonder if anybody could help me as I’m at a loss here.
Recently purchased a mk3 seat Leon and it has idle (1000rpm) and the fans stay running for a few minutes after engine is switched off.
have had the DPF Regened and a chemical clean through it by a mechanic and also the DPF Sensor changed. Have taken it on plenty of long journeys to see if it helps but nothing! Shows no fault codes??
Engine stop/start function doesn’t work it says power consumption is high? Mechanic is now suggesting an electrical issue which is raising the idle and causing the fans to come on. Has anybody got any ideas or been through similar? Don’t want to throw more money at it as I haven’t had it long. Any advice would be greatly appreciated
May 2, 2023
9
The engine will idle at 1k when it is cold/warming, this should go away as the engine reaches optimal temp, if this is the case it's completely normal.
The fans will often stay on for a few minutes after you have switched it off, this is also normal. If the engine needs cooling, it still needs cooling even if you have switched it off. I would say check for air pockets, leaks and check the quality and level of coolant if you want to be sure, but I assume this was the first thing the mechanic did.
Nov 11, 2024
14
Thank your reply mate means a lot. Even after a long journey the idle will sit at 1000 and the fans will be blaring for a few minutes after shut off. The occasional time the revs have been normal and I’ve turned the car off and no fans or anything.., now the winter is coming I don’t want my battery to die. It says power consumption is high will that be causing the revs to sit higher and fans to stay on mate?
May 2, 2023
9
Yeah mate no worries on the fans there. The power consumption being high isn't really to do with any issues on the car either, the power consumption will be high based on things like driving mode (eco, normal, sport), how much you use the air-con, if your lights are on, radio etc. I have always had a high power consumption in the 4 years I have owned mine, it is just because I drive in sport mode with the air-con on all the time.
You mentioned the stop-start doesn't work, so the first thing I would do is check the battery and alternator. Check that the battery is actually a stop-start battery and get a health check done on it. You can test the alternator by removing the negative terminal from the battery while the car is running, if it stays running your alternator is fine, if the car cuts out you need a new alternator.
As for the revs, if it still idles at 1000rpm while at optimal temp, then you may have a fuel or intake issue. I would start by putting some Redex diesel cleaner into the fuel system to clean the pump and injectors, drive it around for about 50-100 miles and see if it sorts it. I would also change the air filter if it has not been changed for a bit as it may restrict air flow to the engine, causing the car to choke and increase revs. Both cheap easy fixes if they work, if not I would then remove the injectors off the car completely to clean them. If you are still having issues, try changing the glow plugs if they haven't been changed for a while. If none of that helps then you may be looking at replacing sensors, it could be cam sensor, crank sensor, MAF sensor, MAP sensor etc. however, these issues are electrical faults so would usually throw up a fault code on a diagnostic scan as the car is unable to read the sensors data correctly. If none of that helps you may be looking at taking it to a dealer or specialist.
When was it last serviced? What's the mileage?
Nov 11, 2024
14
As for the power consumption being high I’ve turned all lights off, heaters air con, radio etc and put it on driving mode normal and still seems to do it so not sure where the high consumption is. Brilliant thanks for the advice for the battery pal I can definitely get that checked out and see what happens.
I can buy some red ex and Chuck that through see if it works, I’d have thought over the weekend I put about 250 miles on it would of helped but it never, car runs fine in itself no issues just the high revs and fans coming and staying on is bugging me. Injectors are they expensive to check or replace? I’m not a mechanic or don’t know much so don’t know where to start all I know is that the car running high idle means it’s doing something and the fans staying on isn’t right lol, appreciate all your suggestions bud and I’ll see if I can get them checked. Apparently the dealership I bought it from took it a specialist to check all the car over and run diagnostics but recorded no faults and said it’s fine with no issues.
mileage is 158k last serviced at 156 in April
Nov 11, 2024
14
Also forgot to mention if you turn the car off and then back on again the fans will go off and it’ll idle fine for a good 10 minutes and then start doing it again
BillyCool
704
275
Leicestershire, UK
The car will idle at 1000rpm if doing a DPF regen. If you switch it off during a regen, the fan will continue to run until it cools. It could be relevant.
The only way to know if it's doing a regen is to check. The best way (and a good way to check your DPF health) is to get an ODB dongle and the VAG DPF app.
This will allow you to see all of the DPF data and whether the high revs coincides with a DPF regen. This is what it looks like:
Normal DPF temp is around 200 degrees C. To do a regen it heats up to 550+. Ideally, you want to finish the regen before switching off. You can check how full your DPF is and how often it regens.
The Carista OBD dongle is really good:
AMAZON
Might be completely unrealated but it's quite a useful tool anyway and the dongle can be used with other software as well. Usually with Carista, you get 30 days free membership so you can do some basic mods as well if you want.
Nov 11, 2024
14
AMAZON
Hi billy thanks for the reply. I did think the high idle and fans running was for a Regen as did the guy working on my car, no matter how long you run the car for the idle and fans still stay running, did 100 miles at the weekend on the motorway still nothing. He reset the DPF and chemical cleaned it, the soot levels are low so not sure what’s going on it’s like it’s not stopping Regen if it is that. Could it be a faulty fan do you think? Or a temperature sensor or something, as I’ve said there isn’t any faults showing
BillyCool
704
275
Leicestershire, UK
Really can't say. Too many variables. Don't know how effective a DPF chemical clean is or what other factors can influence it.
I'd still want to run VAG DPF to see what info the car is getting from the DPF. It's almost like it's in permanent regen.
If the car thought the coolant temp was too high to run the fan I'm not sure why it would idle so high. No way to tell.
Could be a bad fan switch? I have replaced my coolant sensor on the engine block and the mechanic said it was a nightmare to do. I think there are actually 2 sensors. The problem with a bad sensor or switch is it won't necessarily throw up a fault code. My switchable water pump went stupid and never threw a code. Or my blocked heater matrix or my cr@ppy plastic cam cover. The list goes on!
I really would try the dongle and VAG DPF just to eliminate it. Either that or go and speak to a VAG master tech or someone who knows more about it. You can only self diagnose so much.
14
I really would try the dongle and VAG DPT just to eliminate it. Either that or go and speak to a VAG master tech or someone who knows more about it. You can only self diagnose so much.
Thankyou mate I do appreciate that. Yeah it is a weird one that only seems to happen intermittently, stuck at the moment as to what it can be lol
BillyCool
704
275
Leicestershire, UK
Today my car sat at 1000rpm sitting at traffic lights at the end of a 7 mile drive to work. I know it's to do with the stupid VAG `cold start` thing, almost like an autochoke. Only does it when the temp drops to around 4 or 5 degrees C or less. No idea why is feels the need to do it!
I can only reinforce monitoring your regens. It will give you a lot of data and help eliminate that as a possible cause. It almost feels like your car is trying to do a permanent regen.
Nov 11, 2024
14
I drove to work this morning pulled up in the car park and the idle was fine sat at 800rpm and the fans never came on or stayed on, first time it’s done that which is weird. When it does do it if you turn the car off and then back on it’ll idle normal and cut the fan off for a good 10 minutes and then start idling high and fans come on again. I will definitely monitor the Regen mate as I said the mechanic checked the soot levels they was low and ran chemical through it and it was all fine. Surely it can’t Regen all the time it’s like it’s stuck. I’m thinking and hoping maybe a faulty sensor or fan switch. As I said this morning fingers crossed it never happened, will have a good long motorway journey AGAIN tomorrow
Nov 11, 2024
14
UPDATE: drove home from work, half way back I stopped at a set of traffic lights and noticed the idle high again, fans spinning when turned off for a few mins too. I’ve read a few threads and people have said there’s are the same and have been for a long time so I’m not sure if mine is normal for it to do that
andy2max
23
13
Definitely sounds like it’s trying to Regen to me. I would get a obd dongle and monitor the DPF. Did the mechanic take the dpf to clean? How many miles has the car done? I’m wondering if the oil ash level is high.
BillyCool
704
275
Leicestershire, UK
Original OP post said "DPF Regened and a chemical clean through it by a mechanic and also the DPF Sensor changed".
For me - it sounds like the car wants to regen a lot or thinks it hasn't completed one. If the OP is doing 100+ miles drive that might be enough to restart the cycle anyway and also confuse things.
There are also many factors that can influence (prevent) a DPF regen from completing:
  • Low fuel
  • Low oil
  • Low coolant temp
  • Engine light on
  • Blocked DPF
There are some others.
For me - this DPF `clean` and change of sensor may be an issue. I don't entirely trust it. That is why a dongle and VAG DPF app can help you view that data and either confirm or eliminate it as a possible cause. You can see what data the car is getting from the DPF. With the dongle you can also use other apps to monitor real time coolant temps etc to gather more data.
The comments you may have seen about fans running after switch off might be a slight red herring. I've seen the same posts and that seems to relate a bit more to Cupra's and those who drive hard and also have GPF's fitted, which also do regens. Not saying discount it but the high revs suggests it's more regen than cooling related.
Nov 11, 2024
14
Morning billy, thanks for the reply.
I have just over half a tank of fuel in the vehicle at the moment. Before I picked the car back up from the dealer they took it to a Seat specialist in Loughborough for a few other issues I had as well as the cooling fans and high revs and they came back and said it’s normal and isnt showing any codes but I’ve got a feeling something is a miss lol.
I had a look on the car dashboard infotainment thing and the oil reading was at 90 and the coolant at 82°c or the other way around can’t remember but no engine light on. When they did the chemical clean he said it will either smoke or foam at the exhaust and a bit of foam came out and very light brown, so I don’t feel the DPF is blocked.
I feel if the revs are high the engine is definitely doing something and it’s not normal like I’ve been told by a few people.
I don’t have the car with me at the moment my partner is using to go to work which is a 17 mile drive mostly motorway so I’m hoping that could trigger something, told her to keep the revs high also.
If this doesn’t work I’ll be taking it to my usual mechanic who I have a bit more faith in and will more than likely find something wrong with it, but if there’s no codes I suppose it’s a needle in a haystack
Appreciate all the feedback mate, just want to get it resolved now
BillyCool
704
275
Leicestershire, UK
Coolio. The infotainment coolant reading is not very helpful as it's not an exact reading. It will say 90 degrees even if the temp is 80 or 100. It's designed not to freak our drivers as the coolant temp does fluctuate when driving. I suspect the 82 degrees was the oil as the coolant tends to get up to temp faster.
Where are you based?
Nov 11, 2024
14
I’m based in Leicester mate
Nov 11, 2024
14
I'm Melton Mowbray. If you want to use my dongle and phone app, you could check your DPF info. Just see if the figures make sense.
Appreciate that. When the mechanic did a check he looked at all the live data the car was giving out on a tablet whilst the car was running, would that be the same thing as the dongle
