Occassional loss of coolant .... pressure relief??
Dec 21, 2019
9
Hi, I've got a Seat Leon 1.8TDI, and have had a few instances where it has lost coolant (coolant level warning light, etc). I have been monitoring coolant level closely, and after most journeys it does not move at all, including where I have driven hard to get engine temp high, but no loss of coolant and level just stays same (once cooled). But on a short motorway journey (40miles) it did loose about 100-150ml coolant in that one journey. There was a bit of coolant in the places marked in yellow circles in photo. I've never seen any coolant actually leaking / spraying. Does the coolant expansion tank have a pressure relief to vent coolant when pressure too high ? Does where where I saw the coolant match where any vented coolant might end up?
BTW - after the first time of loosing coolant, I saw the posts here about the silica bag in the coolant tank and it looked like the one in mine was burst, so the expansion tank was changed as first measure - but it has not fixed the occassional loss of coolant. I suspect the bits of silica have made a small blockage somewhere and that the coolant system pressure is going up higher than it should, and giving the occassional venting of coolant. But the cabin heating seems to be normal, which seems to be common problem with a burst bag, and the car warms up just as normal. Does the expansion tank cap do anything, as that wasn't changed?
Thanks,
Andy
SuperV8
1,737
838
These are symptoms of a blocked heater matrix.
The heater matrix can get blocked from leaking silicate, left over casting sand or just general detritus in the cooling system.
The matrix is on a micro coolant circuit - shared with the EGR cooler so if this circuit if blocked you can get local boiling of the coolant after a DPF regen, which over pressurises the coolant which escapes out the pressure relief cap.
Probably need a cooling system flush - and a new heater matrix. Do the flush BEFORE fitting your new matrix!
New matrix is fairly simple job - don't need to take the dash out as some dealers try and charge a lot of labour.
Have a search on here for heater matrix - very common.
Dec 21, 2019
9
@SuperV8 - thanks, your comment that the boiling off can be related to when a DPF regen happens is very useful, as may explain why I didn't get any loss of coolant in my attempts to get the engine temp high with some "hard" driving around, and that it seems to happen during motorway journeys. The cabin heater is working, i.e. giving out hot air, but good that you confirm what I have read in many posts on here that it could be a blockage somewhere.
Does where I have seen the bits of coolant in engine bay match with venting due to high pressue ? I've tried to figure out where it vents from, but I can't see anything obvious or have read any clear description.
BTW - my oil temp seems to be a bit higher than is normal, 100degC for normal driving, 110degC for harder driving or when weather is hot. But there are so many variables that it could be anything, something or nothing.
SuperV8
1,737
838
The pressure relief valve is in the expansion tank cap.
As the matrix gets more blocked - you may find a difference in temperature between left and right vents.
My drivers vents where cooler than the passenger vents when on high heat.
Reactions: Andy Clegg
RUM4MO
8,030
1,095
South Scotland
You asked where exactly does the discharged coolant escape from - if you look at your picture, at the LHS of your series of yellow dashes, you should be able to make out a raised section running down the side of the header tank, it is via this flattened tube that the coolant's escape route is which, if memory serves me, terminates at the welded join area of the header tank - that flattened tube's open end should be down there.
Dec 21, 2019
9
Thanks guys - very helpful. Whilst my local garage (not a SEAT dealer) is helpful - it is good to be able to give them a steer on something like this where the problem is more intermittent or subtle. Great to have such a forum.
Aug 3, 2024
Hi
Can you tell us if you solve the problem with coolant losing, I have the same problem when the DPF regen start...thanks
Dec 21, 2019
9
Hi - I've only just had a coolant flush done, and haven't driven the car long enough to know if it has stopped the occassional loss of coolant I was getting. For me it seemed to loose coolant on a longer motorway journeys (which are infrequent), but it has also done it on shorter journeys. I've got a long journey next weekend, so I'll post after that.
mcspook
81
29
Hello,
I have a 1.8tsi and also losing some times coolant. I had a leak from the water pump and had it replaced, but this time I don't have any leaks and have some red residue from the coolant on the rubber that seals with the bonnet after very hot days. After how long do you see a change on the water level?
Sent from my Pixel 5 using Tapatalk
Dec 21, 2019
9
My coolant level can stay perfectly constant (once everything cooled) for many short drives, so it is not a continuous slow loss of coolant. If it does loose coolant after a drive (often a long motorway drive, but not always) and I get the coolant splashes at the front bulkhead / bonnet, it will have lost about 200-300ml (how much new coolant I add to top up to the level it was at originally).
Aug 30, 2024
Hi Andy, I’m having the same issues that you have stated here. Did the coolant flush solve your issue or did you need to get the heater matrix replaced?
Dec 21, 2019
9
It's still loosing coolant, but things have changed .... gotten worse!!
After the coolant flush, it actually started loosing coolant much faster!! Before the coolant warning light would only come on during on long motorway journeys - and even then not every motorway journey. After the flush (and change of expansion tank cap) a drive of just 10 miles the level in the expansion tank drops by about 1cm with coolant around the outside tank, so after just three such journeys the coolant warning light comes on. So it has gone from something that was just an inconvenience to a car that is barely usable.
Its been pressure tested several times, and not loosing anything. Judging by what people have said - the next thing may be the heater matrix changed - but I am getting heat in the cabin from all the vents, so it isn't totall blocked. I'll update this thread if I get some progress.
Sep 9, 2024
7
Netherlands
Any progress?? Same stuff happening on my end and it's going in later this month, would like the update to see if I can steer my garage into the right direction
Dec 21, 2019
9
Update: The coolant loss had gotten worse after previous visit to the garage for a collant flush - level in expansion tank dropping about 1cm even over a 10 mile drive. The hot air into cabin was working, but not as hot as it should be. Anyway, we agreed that the garage should look at putting in a new heater matrix. I only got car back a few days ago, and whilst not driven it much, the coolant level hasn't moved at all and no sign of coolant on outside of expansion tank. So that is progress. Only time will tell if it is fully fixed. I'll check back in a month or so to give update.
BTW - bill for new heater matrix and fitting was £350, which was cheaper than expecting - though maybe not an OEM part.
BillyCool
726
297
Leicestershire, UK
Good to hear. The standard price for a matrix is about £75 to £95. I suspect they did the ghetto DIY fix and not the SEAT dash removal 8 hours by the book version. That's a good price. Did they change the expansion tank to one without the silicate bag? Sometimes the system has a little trapped air and will self bleed. You may have to top it up once or twice but then it should be all good.
Keep us posted. 👍
Dec 21, 2019
9
Hi - when the garage swapped the expansion tank at the start the replacement was one with silica bag. I was going to ask for the one without silica bag, but sometimes you don't want to risk winding them up by coming across as an "expert" by virtue of "reading a few things on Internet". I may get them to change at next service once there is less pressure to get the car working, or may try to carefully remove myself. Sadly I don't have the time or inclination to get under the car myself these days for DIY fixes.
BillyCool
726
297
Leicestershire, UK
You know the internet is always right! 😆
It takes a while for the bags to break down and split, so you should be good for a while.
BTW - the expansion tank is on top of the engine and is a 20 min job. It's something someone could easily do in the future if you wanted it done.
At least you now have hot air should be good to go.
RUM4MO
8,030
1,095
South Scotland
If your car now has G12evo in its cooling system, surely the correct reservoir to fit, if replacing now that G12eco is in the coolant, is the later version without Silicate pouch - these pouches, I think, were only required on certain car engines which could experience higher than normal temperatures, which caused the G13 to lose some of its effectiveness as an anti corrosion - and adding on these Silicate pouches could keep the G13 in "good condition".
BillyCool
726
297
Leicestershire, UK
The silicate bags were added due to another VAG master stroke concept of "coolant for life". The same concept as the 20,000 mile servicing - to appeal to the fleet managers and keep costs down. As the cars now have more aluminium parts in the coolant system, they needed to have the anti-corrosion inhibitor topped up with the silicate bag. Sadly, those bags split and cause other issues.
I've just gone old school and will replace my coolant every 5 years when the cam belt and water pump is changed. Like in the good old days.
Reactions: TheSwede
RUM4MO
8,030
1,095
South Scotland
This was one of the "advantages" for cam belt short service life - and same for cam belt driven coolant pumps that had a hard short life being driven by the cam belt.
I've watched the G13 quickly head towards being acidic in my wife's 2015 VW Polo 1,2TSI 110PS, an engine that was deemed not to need these "top up" pouches, when in reality, it would have helped keep the coolant a bit less acidic, so that is a job I MUST DO very soon, got the G12evo and a coolant vac replenish kit which I've used already.
