Hi,
2014 Leon ST FR 2.0 TDi 184 CUPA diesel. 195000 miles
Had P2463 (DPF soot accumulation fault code), car goes into reduced power mode after about 25 miles but this clears each time with ignition cycle. I took the DPF off (a right pain of a job) and had it cleaned - pressure drop was 60mBar now its 20mBar so the clean was effective.
Refitted the DPF but can't clear the fault code with a Snap-On Zeus tool. The tool has the specific option to reset the DPF after being changed but that doesn't run and the P2463 fault code wont clear.
There are no other engine fault codes.
Have checked the DPF pressure sensor feedback at the connector ansd also with an Autel scanner on live data and that is good - reading just over 1V and 10hPa at idle and a bit higher at 2500 rpm (no load). oddly the Zeus reads 0hPa for the DPF pressure drop - Snap-On technician connected remotely and couldn't get the code to clear, couldn't reset the DPF and didn't know why the Zeus wouldn't read the pressure either.
Anyone got any ideas what may be the issue please?
Thanks in advance, Nick
