GPS Antenna part number and question
mirceaculita
18
Romania
Hi, I am upgrading to a MIB2 system from my basic 5.8inch without navigation. I need to install a GPS antenna into the dashboard, under the speaker grill in the center. What is the part number for that?
Also, did anyone install an aftermarket one that works? Where can I buy one?
Thank you for the help.
serdar_18fr
375
Part number of the original GPS antenna is 3C5035534F
bahyr
70
28
Made the same retrofit. Get mine from aliexpress, working great.
„GPS Antenna Fakra MFD2 RNS2 RNS 510 MFD3 RNS-E For VW Skoda For Benz For Audi“
Reactions: Pac1man
serdar_18fr
375
Aftermarket ones leave a "GPS antenna open circuit" fault in infotainment control unit, due to the voltage difference.
Nothing to worry about but some people care about things like this.
LeylandVCDS
394
233
Leyland, Lancashire
I replaced the factory GPS antenna with an aftermarket one on my previous 2014 Leon, no errors showed at all in the infotainment module (MIB1)
serdar_18fr
375
Then I have to change my wording as "some of the aftermarket ones".
I upgraded my infotainment unit from MIB2 Std (no nav) to MIB2 High (with nav).
Retrofitter guys installed an aftermarket one and it caused a fault in the unit (checked using OBDEleven) and it's still there.
Later I bought an original one but haven't installed it yet.
mirceaculita
18
Romania
Can an aftermarket antenna be mounted in the same slot? I guess not? Im a bit terrified of more rattles inside the cabin 😅 and i’m wondering how well it sits in the dash.
serdar_18fr
375
I don't remember exactly but I believe they have mounted it using something like a double-sided tape.
No rattles.
serdar_18fr
375
Does it have to be installed in a certain orientation or just wherever I find a spot as close to the top of the dash?
At first, they were about to mount it under the right A-pillar cover but I told them to put it in the original place and they were like "Oh, OK".
Then I asked the same thing about the orientation and they mumbled something so I got the feeling that it doesn't matter.
mirceaculita
18
Romania
Oh I see. Thank for the help, Ill try the aftermarket antenna first since its dirt cheap and see how it works.
Reactions: serdar_18fr
