Coolant and heating issues
May 4, 2023
Hi,
I hope you don't mind me jumping on this post. I seem to be having a similar issue and am in need of some advice.
My blowers (internal car fans) aren't working at all. I get no air out of the fans. I'm aware it's due to a blocked heater matrix and a few parts need replacing. I'm getting silly quotes of £1500-£1800. I think they may be taking advantage of me being a single female who doesn't understand cars much.
I want to get the expansion tank and a new heater matrix changed and any clogged pipes replaced and then the system flushed. Does anyone have a list of the parts a garage will need? I just want to make sure they're not ordering parts I won't need and doing work beyond that which I've requested.
(I have a 2013 Seat Leon S TDI)
Thank you.
BillyCool
722
294
Leicestershire, UK
Hi,
Thank you.
If your fan is not even blowing air, that is not down to the heater matrix. The matrix is effectively a little radiator that warms the air when requested. The fan provides the air. The air blower/fan is under your glove box. I'd try to get that working before you look at the matrix. It could just be a fuse or connection.
Ref the parts and cost for the matrix. You need the matrix c.£80 and an expansion tank c.£40. You shouldn't need to replace any other pipes.
SEAT quote about £1300 as their service schedule says 8 hours as they remove the dash. If you find someone who is handy with tools, you can do the DIY fix in 2 hours and the cost of parts. It cost me £120 and 2-3 hours of my time. If you can find someone who can do it, it will save you loads of money.
This is a guide I wrote based on info from this forum and my own experience changing my matrix. I'm not saying that you do it, just find someone who can!
  • SEAT Leon TDi Heater Matrix replacement.pdf
Reactions: Walone and Sammie
May 4, 2023
Sorry, I should’ve made it clear that I get no hot air out the vents inside the car. All I get is cold air (despite being on the hot setting).
Is it still a blocked matrix issue?
BillyCool
722
294
Leicestershire, UK
If you're fan is working but just blowing cold air, even on hot, then it could well be your matrix.
If you find a local reliable mechanic they should easily be able to do the DIY fix and save some £££'s.
