I added Arduino Nano with very simple code for the automatic start/stop off. After ign ON the Arduino sends in 5 seconds OFF signal to the module. Works great. I still have manual button for start-stop override.
Another option (I don't recommend) is to code off battery control module. Should be the same as disconnecting the ammeter plug from the battery terminal. I'm writing as I remember:
1. Module 09 > Adaption > Channel: Target installation of sub bus participants
2. Set the value: control unit for the battery monitoring to NO, default is YES.
