Mib2 High aka Seat Plus for pre facelifted (June 2024 - 370 release):
It's out now for those that have navigation FeCs that allow. Follow the link for the Mib2 High (Seat Plus).
For Mib2 Standard for pre face lifted Ateca (these are the non European export cars) November 2023 late release:
Note for the Mib2 Standard you will need the "workaround" - see several posts up where I cover that. 2019 Seat cars did come with lifelong FeC. In all cases with Mib2 standard back up the card else you have to follow a recover process if you loose for overall.nds file.
Details in the resource, FeCs and all:
Tried without the text changed in the file also, so at a bit of a loss now. Especially as the firmware update has worked fine. I copied the files inside the main folder, one called 'market' and the text file rather than the full root file, might that be why? The system does say it contains the...
www.seatcupra.net
Don't attempt to change trains... that's a conversation on the software thread. Basically each train is updated so the higher number of the train is the one with the fixes in it for known bugs, 02xx say is the last and great than 0245 etc in your case. There is a 03xx, 04xx and an 05xx. Each top...
www.seatcupra.net
GPS and satnav - Updating the inbuilt Mib2 Satnav / Mib2 tricks and Mib1
This resource is applicable to all Seat navigation systems plus other Vag brands which are MIB2 / 2.5. It is built from the knowledge base on the Leon forum from a long running thread which has the advantage of tracking the twists and turns over...
www.seatcupra.net
