Removing silica bag from coolant header tank
SuperV8
1,545
685
As these silica bags serve an important purpose, is it not possible to just periodically replace it with a new one? That's if they're available to buy. I'm assuming they split due to age from going through 1000's of heat cycles which deteriorates the plastic.
The latest tanks are without silicate from VAG. They just use a different coolant.
Reactions: SteveGSXR600K1
SRGTD
2,557
1,403
This is the 'double skinned' version I had in my 2015 184TDI - no removable 'Tea Bag'
You cannot remove this type of silicate repository without destroying the tank.
I have my doubts whether this type can actually leak? and if it did the coolant return flow would have to be strong/fast enough to carry the granules up and over the container which again I doubt as there isn't much flow through the coolant header tank return pipe.
I changed mine anyway to a tank without Mit'Silicate. 'just in case!'
There was a forum member over on briskoda.net forum who butchered their double skinned expansion tank to get to the silicate bag - picture from post on page8 of the discussion thread at the link below;
LeylandVCDS
397
233
Leyland, Lancashire
The pressure in the system would surely allow flow of the granules, they won't be that heavy. If the design is as in the diagram, why on earth have they not built in filters to stop the granules moving away from where the bag is situated?
But do they?
RUM4MO
7,967
1,059
South Scotland
But do they?
I can't see them bothering to fit these silicate pouches if they were not needed, mainly, it seems, with TDI engines, as I've said many times, "is this only a G13 coolant issue?|" and if so, changing to G12evo should let you walk away from it.
SuperV8
1,545
685
But do they?
Cooling systems aren't designed with much flow through the expansion tank. The expansion tank is only there to collect air and allow expansion of the coolant is it gets hot.
Rob McCool
71
13
Birkenhead
I had this tank version on my 2013 Leon FR184 and had the losing coolant problem .Brian Gordon-Stables gave me some very helpful advice on how to change the matrix and expansion tank.I did this about a month ago and so far,so good.
mykro
73
7
and where this coolant goes? onto carpet in interrior or where it leaks ?
csd_19
2,279
28
Angus / Edinburgh
Looks like it's Feb 2020 when the latest bottle revision was brought in (M).
I thought I'd be lucky in my 18-plater (before doing some research) but no, it's the "mit silikat" version and to add insult to injury it's the double walled 'G' revision. Looks like I'll be ordering an 'M' version now (5Q0 121 407 M).
IN fact, I might order two as I'll need to have a look at my folks' 2018 Ateca 2.0TSI as well...
RUM4MO
7,967
1,059
South Scotland
Are you going to replace the G13 with G12evo when you replace the reservoir bottle?
I was servicing the brakes, including replacing the rear pads on my daughter's May 2019 Leon Cupra, I meant to check the coolant with some "test strips" that I have, really just to make sure that the PH level was still okay as it should be as it has one of these silicate loaded reservoirs, but I forgot to bring the test strips out with me to the garage, and her time was tight, so I just topped up the coolant with neat G13, I should try to convince her to change to that non silicate reservoir and change to G12evo in the spring time, I'll use your info on which version meets that criteria, if or when she agrees that doing that is a good enough plan!
Reactions: csd_19
csd_19
2,279
28
Angus / Edinburgh
For the moment I'm just going to top up the new reservoir with 50/50 G13/water and do the change to G12evo early next year.
Reactions: RUM4MO
Nov 11, 2022
I have an Audi A3 2014. My heating stopped working a couple of weeks ago, took it straight to the garage and they gave me the news that this bag had split and I have had to have my water pump & timing belt replaced, my heating matrix, multiple pipes and both the radiators in the car... should be collecting my car today and paying a £2000 bill. I am just so worried now that other damage could have been caused? does anyone know? Also, its all bee flushed out, but am I to expect to have to more issues would you say? I have raised this with Audi and I am waiting for someone to come back to me, I probably wont get anywhere... but what an absolutely stupid thing to put in a car knowing this is happening.
RUM4MO
7,967
1,059
South Scotland
I think that there is an official recovery procedure that some be carried out after this has happened, it will involve flushing sections of the system before fitting the new heater matrix - I would hope, as flushing sections out while the blocked heater matrix is in place is stupid, as is flushing that section after fitting the new heater matrix. Unfortunately, you do need trust that dealer's workshop, this type of failure is a license to print money.
Maybe I should do the "good father" bit even more and grab one of these non silicate reservoirs for my daughter's Leon Cupra.
Just one last thing, is your Audi A3 a Deisel or Petrol model?
RUM4MO
7,967
1,059
South Scotland
I'll admit to being naive enough to have assumed that all reservoirs that had that material within the double skin, would have a properly engineered way to package it - I was wrong!
Nov 11, 2022
Mine is a 1.9 diesel. My header tank says Mit Silikat on it. The garage did flush it all out and replaced some pipes that were clogged too. I spammed Audi on social too, and now they are "looking in to it" I feel traumatised by this whole avoidable experience!
Reactions: RUM4MO
Lord_Nikkon
51
13
Poland
I changed my "mit silkat" tank for newer one without this crap and change "eco" coolant to normal one. Everything in dealer garage. No issue.
