You're not driving fast enough...It’s a great feature, but shame it can’t give it a quick blast of air after to clear water that distorts the lens.
Mine doesn't do this? Do you have to have a certain profile active?.......or do you mean the external rear light bar? I always class the interior LED below the windscreen above the dashboard as the wraparound lighting?When you switch on your hazard lights the wraparound lighting flash’s orange
Internal light bar across the dash. Did it in my VZ Edition (no specific mode) but not in my V2.Mine doesn't do this? Do you have to have a certain profile active?.......or do you mean the external rear light bar? I always class the interior LED below the windscreen above the dashboard as the wraparound lighting?
My VZ2 didn't either, nor have any of the customer cars I've worked on. However they are addressable LEDs and it's possible to make them do some weird stuff. I believe I've seen a video of what jcbmally is talking aboutNope. My internal LED under the windscreen above the dashboard does nothing with the hazard lights on.
Proved myself wrong!!! I used it today and the dashboard led wraparound flashes along the hazzard lights!Mine neither, if not mistaken.
Mine is April build date, delivered first week of June.Light bar flashes with hazards on my VZ3 - Delivered April 22 so guessing March build date
March 2022 ordered Oct 2021What was the build date of your car?
There’s a menu that you turn it on. On the background lighting menu. There a button under the sun button click that then show functions and you can select it thereNope. My internal LED under the windscreen above the dashboard does nothing with the hazard lights on.
Any chance you can take a photo of the screen? ThanksThere’s a menu that you turn it on. On the background lighting menu. There a button under the sun button click that then show functions and you can select it there
