Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
So finally got a black lower double din console (mine was dark grey). Went to fit and noticed the 12 supply doesn’t fit, not a drama a job for later to fit a USB port there. Then noticed I’ve got the grey handbrake cover not black (god knows how)! And to top it off it’s got the small gear gator opening!
Do I cut it (don’t fancy that) or can I buy another gator to match the size? Will get it trimmed to match when I do my wheel if so.
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Ignore the badly marked ash tray cover I will find an eBay replacement - don’t suppose anyone has the correct colour code?
Thai-wronghorse
Self proclaimed Cupra R addict & butcher!
Dec 3, 2015
2,240
1,093
Kent
My old DD lower console had the smaller gaiter recess but I didn't like the gaiter that came with it so I Dremelled it out to fit.
It's not a huge amount to remove so go slowly and carefully or it'll end up too sloppy and pop out as it won't have the factory clip in sections.
I eventually sourced the correctly cut console in the end which also didn't have the armrest slot cut out as well but finding a console in this particular configuration took flipping ages and I've had a lot of DD consoles over the years.
As for the sliding lid ashtray, it's the same as the one used in the mk4 Golf & Bora.
I removed the scratched up gunky rubber coating with some acetone and washing up sponge though and it came up like new plastic.
Sent from my SM-S906B using Tapatalk
Reactions: Scotty_b
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Do you remember if you took all of it out or just the sides?
Was it a Toledo gator that fits or just a specific year for the Leon? May see how much one is to try first (can’t uncut it).
I know what you mean about the right combo, thought I’d lucked out with this having the armrest cut out, that would be easier to cut.
Thai-wronghorse
Dec 3, 2015
2,240
1,093
Kent
You'll basically need remove a small amount from the entire opening if I remember rightly.
It was a long time ago but I'm sure I made a little template up using the gaiter base.
My console set up came out of a Toledo V5 which had an armrest and the smaller no base trimmed leather gaiter.
I didn't want the armrest so chopped and bonded in a coin tray from a standard console.
I used my FR TDI gear gaiter with the wider grey base so had to modify the opening.
Like I say I've now got another console which came from a LCR that was specced with the larger gaiter and no armrest from the factory.
Alexis27
2,144
478
Manchester
Tried to change the knackered linkage bushings with metal ones from Darkside. First one fit like a glove, the second one is obviously machined half a mm too small and now a lot of huffing and puffing it's bloody wedged on halfway.
Need to remove the relay bracket but I can't figure out how to get it out. I can't see how moving the water pipe would help and no mention of having to do that in the Forge short shifter instructions
video: https://www.veed.io/view/91fb41f1-fb2c-4e71-9d95-0e94b33ea109?sharingWidget=true
Alexis27
2,144
478
Manchester
Plan B - managed to get it off. Have just ordered a standard VW linkage. At the least the main one that takes all the load went in no problems. Just a bit annoyed I wasted £25 for one that doesn't fit.
Alexis27
2,144
478
Manchester
New linkages on and forward gears fine. But reverse is now weird and you have to push down, move to bottom left, move up instead of push down, move left, move up 🤔
Have reset the linkages twice.
NEUTRAL:
REVERSE:
Any ideas?
iammooks
1,784
1,172
Sanded and cut my bonnet last weekend. Weather was really hot (not sure anyone noticed) so the cutting compound was drying on the hot bonnet so didn't really do its job. Will try again probably next week.
Feels like I'm a week late but I don't think it's ever been done, so will be doing this at some point.
Has anyone done it? I'm guessing it's an easy job, but not as easy as it should be?
Dazzalcr
302
284
Lancashire
Well had timing belt fitted other day, so decided to take her for a drive, did not get far and car had no power turned out to be coilpack(luckily had some) then 2nd attempt well almost went well till boost pipe pops off, not the garages fault as they were nervous about over tightening it as the pipe is carbon, so drove home again with no power lol. But I have a ultragauge em plus and that alerted me with code for the misfire before engine light came on and vacuum issue as soon as the pipe popped off really good bit of kit
Reactions: Rich.T
Rich.T
1,609
932
Driving to work thismorning and noticed that noise you get on corners when a cv joint is on its way out. Standing in next Saturday MOTing at the local garage so will see if they can sort it whilst im there.
Put £25 of petrol in today at £2.15 a litre. So no, the gauge didnt move far.
  • Wow
Reactions: Dazzalcr
Dazzalcr
302
284
Lancashire
That's ridiculous that price😒, I'd hate to be a cashier cos although it's nout to do with them, they will no doubt be getting some abuse for it.
MoToJoJo
823
653
Northants
Not done anything apart from not melt in the heat.
Did pick up an engine hoist and metalworking vice for £120 so work may actually start happening again (don't hold your breath though)
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Striped my brake caliper off to find out if it’s getting fluid - it’s not…
Would a failing pump cause only 1 caliper not to work? Can only find the main distribution pump (near the air filter) would expect another bias block somewhere - any one have links to diagrams?
