Most likely source of the squeaks from the front suspension ?
serdar_18fr
374
Hi there,
I've purchased my 2018 Leon FR in May 2021 from its original owner. In the first four or five months there were no noises from anywhere. Then I started to hear a squeak from the front suspension when driving over the bumps and I've been living with that annoying noise for the last five months. Later I learned that there's a chronic squeaking problem with Leons and also Golfs. The authorized dealer's solution to this well-known problem is to unmount the suspension completely, clean & grease where it's needed, mount it back and repeat this procedure when the noises came back. I didn't like this solution because I'm not so sure that they are perfectly-capable to mount all the suspension parts back properly. So I didn't go that route but I wonder whether the original owner ever heard the noises too and did something about it.
Anyway, now I consider replacing some or all of the bushes with the polyurethane ones, but I'll be happy if the source of the noise is just anti-roll bar bushes because they are relatively easy to replace. If the noises are coming from wishbone bushes, then it means a lot of hard work, I guess. So, what are your takes on this ? What could the most likely source be, the ARB or wishbones, or both?
Thanks in advance,
Serdar
Reactions: Raymond p j Clarke
xyz
565
204
oxford
Visit site
This is a known problem on the Golf R and is much discussed in the forums. On the R, it’s the top mounts that are renowned for this and just require greasing. Not sure if the whole suspension needs removing or not.
Reactions: serdar_18fr
serdar_18fr
374
Thanks for the response. I'm not so very well-versed on all of the suspension parts so I need to ask: When we say top-mount, are we talking about the part in the photo I attached? I might consider replacing them if they're not too expensive, assuming the new ones will do fine for a couple of years before they start to squeak too. Really don't want to have to grease some parts every three or six months.
Cheers,
Serdar
xyz
565
204
oxford
Visit site
Cheers,
Serdar
I think that’s it. I don’t think replacing them will sort it. It’s a common fault that can only be sorted by greasing. Mine went for over five years and didn’t need doing.
black_sheep
1,255
586
The other thing worth checking is the rubber door seals on the rear door between the B-pillars of the front and rear doors. They squeak when you go over bumps - I use some gummi pfledge every 6 months to stop the seals drying out.
You can test this by pushing and releasing against the front door window.
edmong
GHE Tuning
Aug 15, 2007
567
Plymouth, Devon
Morning all.
My 2014 FR 184 has started getting really bad now.
Are the best options just to poly bush it all?
I think mine is top mounts and dry lower arms but I could be wrong. It's getting worse though so I need to do something.
Tara
591
215
Bournemouth
I would suggest the front anti roll bar bushes although a pain to get to , if you have someone who could put it up on a ramp ? Ask them to air hose all the dust out and try soaking in silicone spray to see if it helps.
Big Vinny
226
49
I did the creaking front roll bar bushes with Red Renolit rubber grease on an Ibiza. It worked for a while. The Renolit grease is specially formulated for rubber components and will not cause swelling or cracking.
SRGTD
2,535
1,389
We've had three Leons and they've all squeaked. I ignore it. Only happens over speed bumps etc so to me it just not worth the cost and aggravation of doing something about it.
The front anti roll bar bushes on my mk6 Golf used to squeak / creak - also only when going over speed bumps, and when the roads were dry. On wet roads, I assumed - rightly or wrongly - that the bushes got sufficiently damp from road spray to ‘lubricate’ them.
Never bothered getting the bushes changed.
edmong
GHE Tuning
Aug 15, 2007
567
Plymouth, Devon
So, I've replaced the lower arms with the ones from Awesome GTI and the Super Pro bushes. This sorted the knock out.
I still had the creaking when turning the steering wheel so I did the top mounts and put ECS ones in with new bearings.
I still have the creaking when turning! It's almost like the springs and rubbing on its mounting points.
It's doing my head in now. Anyone else have the same issue? Do I need to replace the lowering springs and struts?
martin j.
1,997
893
Fife
Try some silicon spray on the top mounts and the mounts where the springs seat, door seals can make a noise a slight wipe over with a rubber lub-sparingly or it’ll come off if you brush against getting in/out- white grease spray on door hinges and catches. It’s hot and miss usually.
edmong
GHE Tuning
Aug 15, 2007
567
Plymouth, Devon
Thanks for the reply Martin. It's not door seals, definitely front suspension. I greased the new top mounts before they went back in. I'll take another look tomorrow
Sep 1, 2021
24
If you did the lower arms and top mounts Inc greasing them up and the squeek is still there. Did you do the ARB bushes as mentioned earlier in the thread?
serdar_18fr
374
I haven't touched anything yet. In the meantime I'm pretty convinced that the squeaks are coming from the ARB bushes but I'm not going to grease them up. I decided to buy polyurethane bushes from Powerflex in a month or so. I'll post the results here.
Reactions: Vauxfan
Cupracabra
40
Could you post a pic on which seal it is that usually squek, i have this problem but it doesn't seem to work with gummi fledge.
Sep 1, 2021
24
You also get queasy from the front seat belt clips on the faux leather seats. It was well annoying. I put a little bit of grease on the underside of the clip and job done
Cupracabra
40
Are they seated on the seat or on the pillar?
The sound is basically near my ear
