It does but their are different specs. VAG circa 2018 had a period when they stopped enabling it although the hardware was installed. Ateca atleast pre the facelift had a camera spec that could handle it, mine was factory fitted, so there were cars out there where you could turn it on. VAG got too clever and fitted lane assist cameras which didn't support it. Obviously you can't get something for nothing..hi, thank you for information. so what about TSR (traffic sign recognition), do i still need hardware?
i found this post, and said the system uses image recognition from the high definition camera which is part of lane assist.
Coding and programming - Enabling Traffic Sign Recognition (TSR) with VCDS / OBDEleven for vehicles with Lane Assist
This mod should work across all recent Seat / VW and Skoda vehicles to 2019 with Lane Assist if it was not delivered as part of an option. Vag group revised programming new 2020 models, check programming documentation of tool supplier for current...www.seatcupra.net
How Leon 4s fit in this I don't know but did come across a VW owner that didnt have the correct lane assist camera that was asking on the Seatcupra site. If you get someone with the part number and possibly firmware release of the lane assist camera with factory fitted TSR and compare with yours. Comes out of Obdeleven etc. VAG can also turn off stuff that goes beyond coding in our terms, then you are stuck if it's that. Rear electric tailgate is an Ateca one of these. Swap codes.
