Hi all,
If you do have the MIB3 infotainment unit (hardware H56 or H57. manufactured as of September 2020) and Wireless Full Link - Apple CarPlay Wireless and Google AndroidAuto Wireless - does not work, it might have been deactivated by the manufacturer.
Utilizing an OBDeleven OBD2-plug with the Pro license, you can simply enable (activate) both with dedicated switches, under the section „Function configuration connectivity“: Mirror Link, Google android auto and Apple car play. There, most probably it was set to „Usb only“, however it must be changed to „On“.
Thereafter, a soft reboot of the MIB3 is required (pressing the touch on/off switch for a while until it restarts automatically).
Moreover, I set ‘App connect over wifi’ to “Yes”.
If, and only if 5 GHz was deactivated, it also must be activated.
Good luck
Jo
Good luck
Jo
